Tips for fellow newbies on diff fluid exchange.
Old Nov 11, 2011 | 11:27 AM
Scottyplo's Avatar
Default Tips for fellow newbies on diff fluid exchange.
After my first differential fluid exchange I have some tips for my fellow first timers.
1st an easy way to make a standard 1/2 inch torque wrench work for the plus is a 1/2 to 3/4 converter.
2nd the fluid pump is handy but the only thing I ended up using was the clear plastic tube. I hooked it up to the bottle and just squeezed the fluid in much faster.
3rd if you take out the top plug first be prepared when you remove the bottom plug. the fluid comes out with pressure and I completely missed the oil drain pan on my first attempt. this can be handled by holding a shop towel in front of it to redirect the initial surge of fluid.
4th. 3qts of fluid is just right. I bought four and had to return one.
5th. I don't off-road as much as I would like so I hardly ever put it in 4wd so the fluid I just changed out of the front diff looked brand new. If you are like me I would say you can wait twice as long for the front diff.
Old Nov 12, 2011 | 06:31 AM
pastorwug's Avatar
Good tips, thanks!
Old Nov 12, 2011 | 06:51 AM
JerseyMark's Avatar
How much fluid per diff did u use? I have tow package so manual recommends diff weight for front and rear. Im hoping I can get away with 2qts for the rear.
BTW, I know the total capacity of each diff but I can't remember how much it really takes when changing the fluid using just drainplug.(its been a while since I changed it on a jk)
Old Nov 12, 2011 | 07:24 AM
Scottyplo's Avatar
i used the full synthetic 140 weight on front and read because it was more convenient
it takes just under 1 and 3/4 quarts for the rear and 1 1/4 for the front.. more or less
I used the go until it oozes out of the fill hole method.
Old Nov 12, 2011 | 07:27 AM
Scottyplo's Avatar
Torque wrenches aren't designed to loosen plugs The clear tubing works but it is a tedious process. And IIRC my diffs took a little less than WOL's write-up. I removed my covers and cleaned the insides up when I changed my fluid though. It's a chance to inspect the gears and make sure everything is working as it should.
People keep saying that its a chance to inspect the gears but ill be honest here i am a computer technician. So i wouldn't know a good gear from a bad one or for that matter what to do if they were bad.
I take the safe approach and just have my mechanic do the diff change about every 60,000 then i do the quick version inbetween.
Old Nov 12, 2011 | 07:37 AM
ER NURSE 407's Avatar
Great info, is there a write up for this? pics?
Old Nov 23, 2011 | 08:41 AM
kttx740's Avatar
Default doh!
I wish I had read this thread prior to changing my diff fluids last weekend. The tips definately would've helped!
Old Nov 23, 2011 | 08:58 AM
JK-Rick's Avatar
Sorry to hijack, but how often should you change the diff fluids?
Old Nov 23, 2011 | 09:46 AM
kttx740's Avatar
According to http://project-jk.com every 15k miles. There is also a write up on how to do the fluid change.
Old Nov 23, 2011 | 10:16 AM
JKZinger's Avatar
If you do a lot of deep water crossings, change it more often! I do mine every 12K.
