OK bs
Old Feb 3, 2011 | 06:27 PM
  #1141
interceptor_1972's Avatar
Originally Posted by snowbilt
The second time I have used it. First was using it to get myself free after getting high centered at Douglas. Both times it didn't seem to struggle one bit.
Good to hear. It definitely seems to be well built and that synthetic rope and wireless remote is a great plus.
Old Feb 3, 2011 | 06:28 PM
  #1142
u-joint's Avatar
Originally Posted by interceptor_1972
I know right .
So I see you finally pulled the trigger on the shafts . How much was the damage? But in the long run, I think this is a more permanent fix than going with replacement stockers . And if David had them in stock, you'll have it in a few days
I went with the Alloy Chromoly ones, they set me back $675 total.
I've actually got another thread going, my hope is to get them installed next Saturday. That should get me back up and rolling.
I just figured the RCVs are:
a) more expensive up-front, and this was an unplanned expensive.
b) put a risk of something (more expensive than a u-joint/axle shaft) being my weakest link
Those two things are kind of the pivotal reasons I went with a Chromoly axle instead of the RCV ones.
Old Feb 3, 2011 | 06:29 PM
  #1143
u-joint's Avatar
Yeah, a winch and new front bumper are high on my want list.
snowbilt, what brand and model is your winch?
Old Feb 3, 2011 | 06:32 PM
  #1144
snowbilt's Avatar
Recon 10500. Bumper is rock hard....twss
Old Feb 3, 2011 | 06:33 PM
  #1145
Originally Posted by jwhitehorn
I went with the Alloy Chromoly ones, they set me back $675 total...
Good choice . Given the fact that you're staying with the D30, this would definitely be the better option. I think after long and serious consideration, I've decided that eventually, when I can afford it, a PR44 will be gracing the front of my JK . So, that also means that regearing and lockers are on hold (originally had those as planned mods for this year).
Looks like we'll be postponing our mod/lift party from this Sunday to a later date when the weather clears up some - hopefully soon.
Old Feb 3, 2011 | 06:35 PM
  #1146
Yeah, a winch and new front bumper are high on my want list...
Definitely a good investment - those Recon winches are sure impressive looking, and for the buck, definitely not a bad option. I love my Superwinch, but having synthetic instead of wire rope sure cuts down on some weight.
Old Feb 3, 2011 | 06:36 PM
  #1147
u-joint's Avatar
Yeah, this is more of a "medium term" fix for me. 3 to 5 years down the road, who knows, I might do the whole D44 thing myself. But right now, its entirely a non-option... heck if I could afford that
You guys could always drive up to Tulsa on the 12th
Old Feb 3, 2011 | 06:42 PM
  #1148
PainKiller's Avatar
I used my winch again today, a toyota tundra( 4 door ) buried in a deep ditch. It pulled my jeeps front end down quite a bit, as I was reeling "in" it would run for awhile and then just stop, I would wait a little bit and it would work again it did this about 10 times. I thought it was the relay but it is puzzling and I would really like to get it figured out in case of emergency situation. any ideas ????
and congrats Jason on making the decision on the axles
I saw ups out today but they didn't come by here to drop off my packages maybe tomorrow
  #1149
...You guys could always drive up to Tulsa on the 12th
I thought of that, but I'll be working that day. Unfortunately, working at a dealership has its drawbacks - Saturdays are generally our busy days, and don't get that off that often. But looks like you're in good hands with the shaft install . Plus, TORN already has all the tools necessary for the driveshaft install having done that himself recently. I just wish the weather would ease up here soon, so life can somewhat return to normal for a lot of folks.
Talking of the shaft, did you get a chance to pop the differential to see if there was any damage done to the R&P or lockers?
Old Feb 3, 2011 | 06:46 PM
  #1150
u-joint's Avatar
Oh, PainKiller, thanks for letting me borrow your Shovel...
Nope... not yet. I can't even get my Jeep in the garage, there is feet of snow right in front of it. Not ideal for working on it, plus I wouldn't want to empty the diff until it's in the garage.
The way I figured it, I needed an axle regardless. I will pop the diff ASAP, but odds are it's a-ok. And if it's not, then nothing lost, I still end up ordering the same amount of stuff.... or at least thats what I keep telling myself
