14.50 on a 9 inch rim
Old Jul 23, 2010 | 08:19 AM
CJ THAT WENT JK's Avatar
Default 14.50 on a 9 inch rim
Will a 14.50 in Tire fit on a 9 inch wide wheel. Very curious.
Old Jul 24, 2010 | 02:51 PM
JKCliff's Avatar
Absolutely! Nothing to worry about! Just watch the back spacing for the rubbing....
Post up the pictures!
Old Jul 24, 2010 | 04:29 PM
mkjeep's Avatar
I ran 8in wide rims on 14.50's on my CJ, never a prob.
Old Jul 24, 2010 | 05:23 PM
joneszj's Avatar
So 13.5s on a 8" rim should be fine? I've been really eyeing up 345/75R16 KM2s.
And you're saying 14.5s on an 8" rim will work without popping beads all the time even though they recommend to run 10" wheels?
Would both the 13.5 and 14.5 tires fit on my 16x8s with 4" of backspace??
Old Jul 24, 2010 | 06:17 PM
JKCliff's Avatar
You won't be popping beads... the concern of running a narrower wheel with a wider tire is long term tread wear and airing down for a wider foot print. The 14.5 is on the wide side....but it would not stop me from running them. The 345/75R16KM2's are good to go! Even the 14.5 with the taller profile gives you the sidewall height that keeps the width from being an issue....
Old Jul 24, 2010 | 08:26 PM
joneszj's Avatar
Sounds good to me...I think the 345s are more realistic considering I plan to run my 30 until i destroy it.
Old Jul 29, 2010 | 07:41 PM
AZJEEPFAN's Avatar
Default WENT TO 10s
I was running these KM2s on 16x8 Enduros but had problems with balancing them on 8" rim- so I went to 16x10 s and had fewer problems with balancing/vibrations. I also think they look much better on a 10" wide rim. I f I remember correctly BFG specs these tires on a min 9.5 wide rim.
Old Jul 29, 2010 | 09:12 PM
joneszj's Avatar
So...anybody got any pics of these?
