15" wheels
Old Apr 17, 2013 | 02:28 AM
Kaptain17's Avatar
Default 15" wheels
Hey guys.
I'm in the market for some 15" wheels. I'm just curious what some of you guys are running. I'm looking to purchase some in a week. I'm trying not to encounter any rubbing on the calipers. Thanks in advance
Old Apr 17, 2013 | 02:33 AM
madmike232's Avatar
I know the mb72s work. I am not a huge fan of 15s on the jk but I do love the price of them!
Old Apr 17, 2013 | 02:37 AM
Kolton10's Avatar
A lot of them are going to rub, my cragar soft 8's did but I just grinder the calipers and problem solved
Old Apr 17, 2013 | 08:50 AM
afpilot82's Avatar
JK-Forum Ambassador
Here's 2 threads for you to read through. Any rubbing usually occurs with steel wheel, alloys are good to go. I run the MB72s and have no complaints. There's plenty of info on the site about this, search around a little.
https://www.jk-forum.com/forums/jk-s...s-thread-7758/
https://www.jk-forum.com/forums/spon...wheels-120933/
Old Apr 17, 2013 | 09:54 AM
Scallywag's Avatar
Ion Alloy 171 15x10, with 35" Cooper Discoverer. Great setup!!
I've had it for about 2 months now and love em! The guy at the tire shop doubled up the stick on wheel weights for some reason which rubbed the calipers so I just took some of the weights off and they are perfect. I've had em up to 80 mph no problem. Eventually, I thinking about getting internal balance beads and do away with the stick on weights just for peace of mind but the weights work fine for now.
Good luck on your purchase and be prepared to hear alot of salespeople tell you 15s won't fit a JK!
Old Apr 17, 2013 | 11:13 AM
Baddintentions4u's Avatar
I have 15's and the problem with these wheels is that you're pretty much limited on the size and brand of tires you will be able to run. The largest tire for most brands is 35's, if you plan to move up on your tire size the only brands I've ran across is Toyo and Pitbull and Toyo will only go up to a 37 and they are pretty heavy tires, about 93lbs per tire. Just keep in mind what you want and what you're getting involved in. Luckily I also have a set of 17 in. rims so I'm able to swap as desired.
Old Apr 17, 2013 | 01:26 PM
stagedtrip's Avatar
I have 15s cragar soft 8s. Took a bit of work but i really like the look of em wrapped in 35s. And saved cash 5 cragar soft 8s $294 shipped. 5 cooper discoverer stts 35x12.50x15s 1240 mounted and balanced
Old Apr 17, 2013 | 02:41 PM
PG-JKU's Avatar
Ion Alloy 171's but in the 15x8 size and only running 33's.
To be different, here's a pic from the back of the wheel showing the clearance to the front caliper.
and from the outside
ID:	448019   Click image for larger version
Old Apr 17, 2013 | 03:17 PM
Kaptain17's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=448014"/>
Oh cool. So u had no problem with the calipers rubbing right?
Old Apr 17, 2013 | 04:10 PM
PG-JKU's Avatar
Nope. No problems at all.
