15" Wheels???
Old Aug 14, 2013 | 05:15 PM
MoyDib's Avatar
I run 15" soft 8's. I like them, only issue is as stated above can't do beefy tie rod ends.
Old Aug 14, 2013 | 05:33 PM
Phishy's Avatar
15" MB TKO here, no issues, love them
Old Aug 14, 2013 | 06:14 PM
superjk10's Avatar
Im running 15s on my 2010. Love it!!!
Old Aug 14, 2013 | 07:38 PM
jsj4raiders's Avatar
I just took my 15's off last week and replaced with 17's. I bent stock tie rod and upgraded to a synergy, which cleared the wheels by an 1/8th inch. Ended up with the TRE's grinding a little on one wheel. If you know you'll never upgrade tie rod then go for the 15's, if not certain stick with 17's. Tires were about $100/tire more than 15's.
Old Aug 14, 2013 | 07:50 PM
JurassicJeep's Avatar
Is anyone running 15x10 wheels? I've ran 10" wide wheels on multiple YJs and loved them. I'm now looking for a set for my '13 JK. So far I've only found a few steel wheels. I would rather run 10's with 3.75-4.00BS vs running spacers. If anyone has experience with 15x10 please let me know along with the brand. Thanks!
Old Aug 14, 2013 | 07:57 PM
karls's Avatar
15x10's here! There were the pro comp alloy wheels but they've since discontinued the wheel. I keep them in my garage for when I find another set of tires to set on them. I believe they're right at 3.5" of backspacing or close to it. I ran a couple different sets of 10.5" wide wheels on them for the beach down here and it worked great.
I run spacers in addition to the wheels (though not needed or recommended) because I want to stay out of everyone else's ruts down on the beach.
Sent from my DROID4 using Tapatalk 4
Stock coils and my 15x10's with 10.5" tires
15x10's and 10.5" tires on the TJ too
Old Aug 14, 2013 | 08:03 PM
Garrett J.KU's Avatar
my 15s fit also, basically when you go to get them make sure there 3.75 or 3.6 back spacing or -19 offset, the backspacing is the key. mine are 15, 3.75 bs, -19 offset pro comp street locks
Old Aug 14, 2013 | 08:06 PM
rockyjk07's Avatar
I've got 15x10 pro comp soft 8's with I believe 3.5 backspacing everything clears just fine!
Old Aug 15, 2013 | 04:08 AM
Thanks guys! That's exactly the help I needed. I will post pics when I get it together.
Old Aug 15, 2013 | 04:12 AM
kh202's Avatar
If you plan to wheel it and air down a lot, I'd recommend an 8" or 9" wide wheel vs 10". Sure 10" works, but it won't hold a bead as well at low psi. Friend of mine has 15x10 and 35's and has on occasion burped air at 15 psi. I regularly air down my 15x8 to 8-9 psi with no issues. Just an FYI
