View Poll Results: Did 15 inch Wheels fit on your JK? I dont care about Backspacing.
Yes they Fit with no rubbing.
16
64.00%
They didn't fit or i had rubbing/grinding.
9
36.00%
Voters: 25. You may not vote on this poll
15" Wheels Yes or No
Old Dec 22, 2008 | 12:56 PM
eraujk's Avatar
Default 15" Wheels Yes or No
Do you have 15" wheels? Do they fit around the calipers???
Discount tire says they wont but from the wealth of knowledge on this site i know they do for some.
Vote and then explain if you want. BUT VOTE! I must know!!!
Old Dec 22, 2008 | 01:00 PM
MJS_Jeep_888's Avatar
I'm running 15" Cragar Soft 8s, WITH spacers. Without the spacers, I don't think they'd clear the calipers (although I haven't tried w/o spacers).
Old Dec 22, 2008 | 01:02 PM
eraujk's Avatar
you running the spidertrax 1.5" spacers? How far do the wheels stick out past the fenders? Any Pictures?
I have the 1.5" spacers and i would be willing to keep using them if i got to use 15" wheels.
Old Dec 22, 2008 | 01:06 PM
racer83l's Avatar
my opinion, mine would stick out too far (They have 4" BS) with spacers. but they didnt rub. Then I rotated them and one of them rubbed slightly for about 10 miles.. now it clears just fine, i didnt do any grinding. I voted they fit. And I have cragar soft 8's (I think they are branded Unique Soft 8's) bought them from Dicount tire, they told me they wouldnt fit but I ordered them anyway. couldnt be happier with them and if I were to do it again, id go with the exact wheels but 35" tires
Old Dec 22, 2008 | 01:10 PM
wiredawg_mg's Avatar
Looks like it is a matter of offset, if you have enough you have a shot.
Old Dec 22, 2008 | 01:25 PM
eraujk's Avatar
Im almost tempted to go back to discount tire and ask them to do a test fit. Just slip on the wheel and check. Its the front calipers that are bigger correct??
Old Dec 22, 2008 | 02:04 PM
casaintsfan's Avatar
procomp series 97 rockcrawlers 15x8 w/ 3 3/4 back spacing
no rubbing of the calipers.
Old Dec 22, 2008 | 02:09 PM
N2MWL's Avatar
Mine fit with no rubbing.... Pro Comp Series 152 (15x10)..
without the mud....
Old Dec 22, 2008 | 02:49 PM
guinnessisgood's Avatar
No rubbing at all but I can look and see that it is really close.
Old Dec 22, 2008 | 07:12 PM
bama JK's Avatar
Originally Posted by planman
For a short time, I ran 15x8 Cragar Soft 8s with 4" backspacing. I had to grind a small amount off my calipers as pictured below.
Then, I sold the wheels and tires to a friend with an 07 Unlimited X. His calipers look different than mine--probably because he has a Dana 30 front axle compared to my Rubi Dana 44 front axle. He had no rubbing at all.
The real questions should be:
"How many with Dana 30s had to grind?"
"How many with Dana 44s had to grind?"
I'v got Crager soft 8's with 4"BS and i had to hit the same spots with the grinder as you did and my has the D30.
