15" x8"rims
Old Nov 19, 2007 | 06:22 PM
mikeyfl's Avatar
15x8 3.75bs cragar street locks... no caliper rub, slight rub at full turn with 35x13.50 toyo mts on a 3" FTU HD lift.
Old Nov 19, 2007 | 06:45 PM
Geeper4x4's Avatar
Originally Posted by joker
y 15's and not 16's.. does it affect the calipers or someting i ask cause i am planning on ordering the 8179 series pro comps as well and would like to get toyos 33 x 12.50
The reason I chose 15 over 16,17 or larger was partly financial. The same outside tire diameter (33 or 35) in 15 is less expensive than a 16,17...times 5 and times the number of times I replace my tires. This does add up over the life of the Jeep and I actually think the more tire small wheel also looks better. I know the trend is to have larger wheels and for those that like it good for them. It is just my personal preference.
I am new to Jeeps and make no claim of knowing much about trail and rock wheelin, but I think that a larger tire area provides more cushion when aired down to climb over obstacles. Now I will let more knowledgeable people correct me if I got this all wrong.
Old Nov 19, 2007 | 06:46 PM
ThinkMud's Avatar
Originally Posted by ralfs56
Just because this joker did it, don't think that grinding on calipers to make wheels fit is a good idea. I know that Jeep would have spent the money on all that iron if they didn't think it was important.
Yeah, what this joker said about that other joker.
actually I wouldn't recommend grinding the break calipers if you don't have to. I had to b/c I already bought the wheels and tires... but it's fine, no issues for a while now. remember my JK was built in the first month of production, and I have had a few issues that others have not. I've had a few parts and seals not be the correct ones, so it wouldn't surprise me if my front calipers and/or breaks where different then others as well. I've had some manufacturers scratching their heads b/c their parts (that were actually Jeep parts) did not fit my stuff.
Old Jan 10, 2008 | 01:11 PM
40yrofjpn's Avatar
I test fitted Unique 15 x 8 soft 8's, (Unique is the manufaturer of the 15x8 Cragar Soft 8's.) They were 4.00 BS and -13 offset. They would not go on without grinding the brake calipers. I ended up installing Unique simulated bead locks 15 x 8 3.75 BS with -19 offset. (these are the Crager street locks.)
and have 1/8 inch caliper clearence. I have a 07 JK Sahara Unlimited.
In my opinion only 3.75 BS with at least -19 offset is the way to go without needing spacers.
Old Feb 6, 2008 | 05:07 AM
Jeepmed's Avatar
Originally Posted by Geeper4x4
I also have the ProComp 8179 15 x 8 in the 5x5 bolt pattern and 3.75 bs with 33 BFG Mud Terrain. No rubbing for normal driving. With the front sway bar disconnected at full articulation you could expect a little rubbing without a lift. I have no lift yet. I will put on the TF 2.5 bb soon and this will fix my trail issue.
Geeper4x4. Are the tires 33X12.50 -15, or 10.5 15?
Also any problem with the tire monitoring sensors?
Old Feb 6, 2008 | 11:57 AM
Discount Tire's Avatar
Sponsoring Vendor
15x8 -19mm offset (3.75" BS) MB72 wheels
35x12.50.15 Goodyear MT
*This was a test fit, as you can tell by the Nitto's on the opposite side. The wheels cleared the brakes without spacers.
Old Jul 14, 2008 | 09:01 AM
In5ane's Avatar
So the Cragar soft 8's 16x8 with 5" of backspacing won't work without rubbing?
Old Dec 29, 2009 | 09:42 AM
bareass's Avatar
anyone know if the american eagle alloys series 185 work in 15 without grinding?
Old Mar 20, 2010 | 09:35 PM
LVE's Avatar
LVE
Good to know. Thats the setup I wanted but I believed the seller and have 17X9's. This sucks because even though they use less rubber, they charge more for a 35X17 than a 35X15.
Old Mar 21, 2010 | 06:02 AM
MELONHED's Avatar
Don't know about grinding 1/4" off but, mine scraped just barely. I had to shave about 1/16" off the front surface. The area I ground has so much meat to it that 1/16" was really not a big deal. And, actually, most of it was extra material from the casting. JK's that have clearance issues are Rubicons, like mine.
