16 in vs. 17in
Old Nov 9, 2007 | 07:33 PM
Smoke6's Avatar
Default 16 in vs. 17in
Is there really benefit going with one or the other? Other than my Jeep being an inch taller w/ 17s.
Old Nov 9, 2007 | 07:37 PM
Robar's Avatar
17's will not make your Jeep an inch higher than 16's alone. You would have to also increase the size of the tires. You could get a specific tire size such as 33" with a 15, 16, or 17 inch wheel.
Old Nov 9, 2007 | 07:45 PM
armycop's Avatar
Tires for 16" rims are cheaper. Height depends on tire height, not rim size.
Old Nov 9, 2007 | 07:50 PM
Robar's Avatar
That is what I was trying to say.
Old Nov 9, 2007 | 07:53 PM
Smoke6's Avatar
Makes sense. So other than tires being cheaper, nothing?
Old Nov 9, 2007 | 08:37 PM
Dropkick's Avatar
The size of the rim also affects the amount of sidewall you have (if you assume the size tire). A 35" tire on a 17" rim has less sidewall than it would on a 16" rim. It's not a huge difference, but a difference nonetheless. Less sidewall means less opportunity to gouge or puncture your tire on rocks or other debris in tight spaces. Or so I've heard.
Old Nov 9, 2007 | 09:53 PM
JUSTIN01's Avatar
Less sidewall means MORE chances for offroad damage to your rims. I don't think you want to protect your tires....... However, onroad driving on a larger rim is generally more predictable with less sidewall "play".
Old Nov 10, 2007 | 02:04 AM
pearl-drum-man's Avatar
Larger wheels will generally handle better on the road, do to less sidewall from the tire and more stability, this is why you see performance cars with large wheels and low profile tires. Offroad, more tire/sidewall is desirable, especially for airing down and rockcrawling where more tire will benefit traction. THis is why it is common to see people who wheel their Jeeps hard to go down a size in wheels when going to larger, more aggressive tires. It's all relative though, if you're going really big with the tires then you'll see more 17's, etc.
Old Nov 10, 2007 | 05:49 AM
Renegade's Avatar
I would rather damage a wheel than a tire. The tires are more expensive (not that this is actually a valid arguement for a larger wheel diameter).
Old Nov 10, 2007 | 05:58 AM
BLKRUBI's Avatar
Not my wheels, but then again, beadlocks aren't cheap, but most wheels probably fall into that catagory.
As far as 16's or 17's go, pick what you want, a 1/2" difference in side wall height is not going to make a significant difference to you.
