18/59's and a BB?
Old Feb 22, 2013 | 08:30 AM
darkhelmet's Avatar
Default 18/59's and a BB?
Hey there folks,
Is anyone running both the higher rate Jeep coils AND a budget boost on a 2-door? I removed my AEV budget boost to put on 18/59 springs and Rubi-Shocks, but wonder if I would still be w/in tolerance to run stock driveshafts on a 2-door if I put the pucks back in on top of the new springs. From what point of "stock" is this 2" maximum lift figure calculated from? Any experience or ideas?
Old Feb 22, 2013 | 08:48 AM
Jeepin Dad's Avatar
I am running a 2" BB and 17/58 springs with Bilstien 5100s, for 2.5-3" of total lift. I have had to swap out the rear shaft for an aftermarket one and have driveline vibrations that has caused ujoints to fail, I am adding adjustable upper rear control arms to correct the pinion angle. I have not had any problem with the front driveshaft.
Old Feb 22, 2013 | 09:09 AM
darkhelmet's Avatar
That is pretty much what I was afraid of. Thank you for the reply.
