2.5" lift upgrade
2013 jeep jk. I have a teraflex 2.5" lift. Looks like springs are sagging was thinking about upgrading to metal cloak 2.5" dual rate coils and fox 2.0 shocks.
Any input or suggestions would be greatly appreciated.
Thanks
Thanks
It's hard to knock any MC product. I'd prefer the MC springs over what you have for sure. That said, you could also just pop a couple leveling spacers in on top of current springs to even things out and roll on having saved a lot of money. It's not like you're jeep is going to be monumentally better from a functional standpoint swapping to different lift. Maybe you're just wanting to though and sagging is the justification
The Fox 2.0 shocks are going to be very similar to Bilstein 5100's......a little on the stiff side. You may or may not like that. The RockSports might be next option if you don't want something as stiff.
Yep, if you talk yourself into new coils, you could do a lot worse than MetalCloak. I'm running their 3.5's now. A bit too tall maybe, but I like them a lot.
Have you researched the height you might expect from the MC coils, when compared to how much actual lift height was gained with the TF coils? Their might be a bit of difference. What additional components do you currently have installed? (caster correction, axle centering, etc.)
No experience with the Fox shocks, but as noted above, I thought the 5100's were very stiff - so if they do indeed have similar characteristics I would not be happy with them. For me, the OME LT's (that MetalCloak used to sell with their lifts before they released the Rocksports) worked out much better. From what I understand, the new Rocksports have equivalent specs to these ome's.
