2.5 TF coils and Adj control arms question
Old Feb 11, 2013 | 12:25 PM
rattler_thesnake's Avatar
Default 2.5 TF coils and Adj control arms question
I am going to a 2.5 TF lift on my 2 dr JK ( kit was ordered as a 2.5 JKU kit before they were 2dr/4dr specific so should net a 3 inch lift).
The qustion is should i go with both upper and lower adjustable front and back or just the front lower and rear uppper like the TF directions recomend?
Thanks for any help.
Old Feb 11, 2013 | 12:41 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Front lower/ rear upper/ front adjustable trackbar.
Old Feb 11, 2013 | 12:47 PM
Thumbs up
What i thought.... Save me a little $
Thank you Mr. TerraFlex.....
Old Feb 11, 2013 | 03:12 PM
SpicedCrusher's Avatar
For what it's worth I'd install the lift and drive it first and see what you think and how it handles. I'd definitely add the front trackbar to re-square the axle. I added the front lowers after and it made all the difference. No real need for the rear uppers but if you want to spend the money go for it.
Old Feb 11, 2013 | 03:37 PM
holy_crap's Avatar
X2 on getting at least the adjustable track bar.
Old Feb 11, 2013 | 03:57 PM
AirJordan613's Avatar
What about aev brackets in the 2.5 position instead of control arms?
Old Feb 11, 2013 | 06:46 PM
4x4chick's Avatar
If you are not concern about ground clearance, then do the brackets. But if you want to lift the Jeep for more than just the looks, then do the control arms.
Old Feb 11, 2013 | 06:51 PM
JohnnyQuik's Avatar
Rear arms are only needed if you require an aftermarket rear driveshaft. At 3" you'll probably want longer front lowers to correct caster to help steering feel and control. Drop brackets are fine if you don't mind giving up some ground clearance.
Old Feb 11, 2013 | 11:37 PM
hooper's Avatar
I have added all four adjustable TF control arms to my TF 2.5 coil lift. They are all set the same length as the stock ones. I got them for when I decide to go taller. I would surely get the adj. trackbar though.
Old Feb 12, 2013 | 02:34 AM
kjeeper10's Avatar
Vet Army
FYI
if you are going with a 4 arm setup. The rear part # is 1654840 and not 1654800
http://www.northridge4x4.com/shop/te...set-up-1654840
