2.5inch bb on stock 2010 jeep wrangler sahara unlimited with factory wheels and rims.
Old Nov 20, 2013 | 06:44 PM
Scheppy's Avatar
Originally Posted by nthinuf
For pics, go down to JK Show & Tell. At the top is the Show Off threads, divided into categories
You could also open the faq's, right at the top of this modified area
thx for that, my first day here so THANKS
Old Nov 20, 2013 | 06:47 PM
Jeek.OlllllllO's Avatar
Originally Posted by Scheppy
so i measured my tires once again, and its wierd but its just over 30inches. so idk, to dark for my to see the numbers, im not the first owner....so im gonna have to see if the numbers match what you said. ill check it out first thing tomorrow.
Yeah it should be unless you have the 16 inch wheels with the small ass tires that the sport comes with
Jeepin on a budget!
Old Nov 20, 2013 | 06:49 PM
TheDirtman's Avatar
What does the tire size read on the sidewall? I can verify mine when my wife gets home with her Sahara. The stock sport came with a 30" tire, mb somebody swapped them out.
Old Nov 21, 2013 | 08:21 AM
Darkjk's Avatar
I have a 2.5 coil spacer on my 2010 2 Dr and I'm wanting to go with a 3.5 lift. Would it be stupid to try and use the spacer lift I already have to add height to the new lift to make it 6" total? I'm fine with just having the 3.5 added but I figured if I already had the spacer that that I could just add it and get some extra height.
Old Nov 21, 2013 | 08:29 AM
Scheppy's Avatar
on the tire it says, p255/70R18 112S M+S. Does that help?
if thier not the same as yours then sombody swapped them shit.
Old Nov 21, 2013 | 08:42 AM
Nope same height, yeah they are 32's like mine just a bigger rim well one inch
Jeepin on a budget!
Old Nov 21, 2013 | 08:59 AM
Scheppy's Avatar
Jeepin on a budget!
how do i measure a tire then?? cause when i masure i get a mear 30 pissn inches??
maybe litle over? my tires prob still have 30% tread..., could that b a hieght factor. o well, so i know thier "32s", thx
Old Nov 25, 2013 | 06:20 AM
sillybubba's Avatar
The sidewall is approx 7" (70% of 255mm)
The rim is 18"
18"+7"+7"=32"
Hope this helps
You are measuring with a tape measure that may or may not be level, the air might be low in the tire, the tire could be worn, or you may not be in the centre of the wheel........hope this helps
