2.5inch spacers
Old Sep 14, 2008 | 01:49 PM
JK-Q8's Avatar
Originally Posted by Ryno
Are you lifting mainly to increase ground clearance, or to be able to fit larger tires? Or both?
mainly looks, i know its a bad reason,but all we have here is sand. Its looks for now, then when i have more cash i will get a proper lift and bigger tires,
Old Sep 14, 2008 | 02:14 PM
Ryno's Avatar
Why don't you just hold onto the $250 that a BB will cost you and put it towards a proper lift and tires when you save up enough money? IMO a lift doesn't really improve the look of a Jeep unless you add bigger tires. Then again, a BB might be perfect for your needs if the only off-roading you do is in sand.
Old Sep 15, 2008 | 01:05 AM
SLeepY_BoY's Avatar
all we have here is sand to, the TF BB is a very good option, ive also ordered it for my jeep.
Old Sep 16, 2008 | 12:43 PM
JK-Q8's Avatar
the lift will be in 3 years so i dont want to wait so long. I am waiting not because of the cash its because of the waranty, my dealer said that if i only add spacers its fine but if i change the suspension and stuff i loose my waranty. thats why i asked if there is a lift that only has spacers.
Old Sep 16, 2008 | 06:22 PM
pastorsteve's Avatar
Rough Country (a sponsor here) has their 2.5" BB on sale for $139. You'll not do better than that.
Old Sep 18, 2008 | 02:52 AM
JK-Q8's Avatar
Cool, and is it just spacers? or whats with it? and is it a good bb lift?
Old Sep 18, 2008 | 08:16 AM
Just go to Rough Country's web site and go to Jeep lifts you'll see you can buy it for the $129 or add shocks to the kit. Looks good. It's more than just spacers.
That and front disco would be all I need.
Old Sep 18, 2008 | 03:55 PM
JK-Q8's Avatar
And if i want just spacers is there a lift i could get? will it also take the rake away?
Old Sep 22, 2008 | 09:12 AM
JK-Q8's Avatar
Originally Posted by S10x1000
The rough country 2.5 is what you want. It's the cheapest ive seen and it is basically just spacers and shock extension brackets i put mine on in 3 hours pretty easy install.
And did it eliminate the rake? will you be able to a post a pic or 2? and if i dont have the rake in some magical way will it lift my front more than my back?
Old Sep 22, 2008 | 11:21 AM
JulianK's Avatar
I'm also curious if it'll remove the rake. If it does, this is the perfect kit for me and my soon to come 33's.
*Edit*
I just spoke with Rough Country and the 2.5" kit will remove the rake. The front spacers are 2.5" and the rear are 1.5". The 1 3/4 kit will NOT remove the rake as both spacers are 1 3/4".
