2" DBS BL w/ manual trans question
Old Jul 5, 2008 | 12:50 AM
rkwfxd's Avatar
Default 2" DBS BL w/ manual trans question
Has anyone installed the 2" DBS body Lift on a JK with the manual transmission? How much of the shifter boot did you have to trim? I have searched but so far the only folks I have seen install the 2" kit did so on an automatic JK and no trimming was required. I know that with a 1" BL on a manual trans model trimming is needed so I assume it is the same with the 2" I just want to know how much.
thanks
Old Jul 6, 2008 | 06:24 AM
rkwfxd's Avatar
Bump.
So no one has installed this kit on a manual shift JK?
Old Jul 6, 2008 | 01:22 PM
jeepnyak's Avatar
on the 2" BDS, i cut the hard plastic on the inner boot about 3" wide. I also had to trim the metal (jeep) about half an inch back in the area where 2-4-6 and Reverse hit. I think the little bit of trimming is worth the extra 2" of height. I only installed a couple days ago and i am away from the jeep for a week. i will have pics next week for you.
Old Jul 6, 2008 | 07:25 PM
rkwfxd's Avatar
Thank you. I'll look forward to the pics.
