2 door 5.5 rock krawler
Old May 27, 2013 | 07:23 AM
zero_traction69's Avatar
Default 2 door 5.5 rock krawler
Any two doors running 5.5 rock krawler lift, if so can you measure from the ground to the beginning of your top right by the door.... I am at 52.5in Nd I am sitting 2in taller than my friend with 3.5 and 35s I want to know if I got the wrong springs thanks!!!!
Old May 27, 2013 | 09:22 AM
Maertz's Avatar
Way to big of springs for a 2 door imo. I have the 3.5 and got 5 inches on mine.. Id go 2.5 on a 2 door.. You will get close to 4 wicj is perfect imo.
Old May 27, 2013 | 09:38 AM
kh202's Avatar
Yeah if those are the tires you're running I'd call rock krawler and have them swap you some 2.5's. I'm sure they'd hook you up. But yeah the 3.5" springs on a 2 door won't give you 3.5", much more. You probably do have 5" lift there, which would be great for 40's
