2 questions ....
1. Can your differential, leak completely empty. Will the gears and pinions/c clips etc etc .... get damaged badly if there was metal shavings in it before (going offroading) and a big leak coming out of a gasket, that wasn't FIXED CORRECTLY?
2. What the heck is up with the ESP light and the swerving car? It came on after four wheeling and hasn't gone away. I have done the diagnostics with the key turning .. and the mechanics shop, it had nothing turn up either on the little computer when they ran the test. Is this a defect?
I am a girl, still learning, and slowly .. but it'd be awesome if anyone could give me some insight?
2. Is your steering wheeling NOT straight? If your wheels are pointing directly forward and the word "JEEP" is NOT directly across then you need to adjust it.
After the adjustment then drive it a little and the lights will go away, just did this to RubyDoo monday. PM and i will give phone #to me if you need help.
Kat
