2008 Sahara unlimited factory soft top on 2010 unlimited sport
Ok just looking for some confirmation.
im about to buy a new in box factory soft top from a 2008 Sahara unlimited for my 2010 unlimited.
the guy has two boxes one are the windows and a bigger box. As well as the actual support for the top. I'm 99% certain the 08 Sahara top will fit my 2010. My concern is hardware. I'm assuming the hardware should be included in these box or wrapped up in the supports correct? Is there a chance I'll need to buy other hardware? (See the picture below for what he has).thanks!
well this isn't going well
i did read that prior to 2010 the tops leaked a lot
starting to have seconds thoughts but this price is really hard to pass up
anyone know anything?
You should have 4 piece door surround + 4 wing nuts for the door surrounds, a tailgate bar, and 2 tailgate bar clips. In the box you should have the rear window and 2 side windows.. The 2008 top will fit all the way up to 2016 with the appropriate door surrounds.
Do do you think I'll need to buy different door surrounds?
Awesome thanks for the help.
as far as you know those two boxes and the supports in the picture should have all the hardware etc?
If your vehicle came with a hard-top only, you'll need the brackets that go on your diagonal roll bar braces.
Dealers will need your vin # to make sure you get the right ones.
They are less than 40.00.
As for all the parts, I think reading above, they have it covered.
Good luck!
