2010 JK suspension and ABS issue. HELP!
Old Oct 10, 2016 | 10:18 AM
Dhaupt593's Avatar
Default 2010 JK suspension and ABS issue. HELP!
Info on my jeep:
2010 unlimited sahara
3.25 rough country coil spacer lift
295/70/18 tires on stock rims
Dual steering stabilizer
Flipped drag link
Adjustable track bar in front
Teraflex track bar bracket in rear
So the most recent installation was the track bar bracket for the rear. Without a doubt made the truck drive much smoother. However, i still couldnt correct this issue. When i hit a bump that causes the body to "roll" and the suspension to bounce, the traction control light flashes and my ABS kicks in and brakes the truck itself. Not to a complete stop, but it brakes hard and i lose control of the accelerator for a second. The problem was definitely happens less often since the track bar bracket installation. But it still happens enough to cause concern. Please help. I havent found anyone else with this problem anywhere.
Ps.. the speedometer is calibrated to my tire size.
