2012 JK Clutch Options?
Old 06-09-2016, 04:16 PM
rd0t's Avatar
Default 2012 JK Clutch Options?
Hey Guys,
I'm looking to replace my clutch, not sure which route to go. If I'm going to be replacing the clutch I want to put something good in there that will last. I was leaning towards either a Centerforce or a SPEC Stage 2+. Any info or suggestions would be a great help.
Thanks
Old 06-09-2016, 04:32 PM
jimhut2000's Avatar
Center force is very good.
Old 06-09-2016, 05:00 PM
jktonka's Avatar
I'd also be interested in this
What difference would an aftermarket clutch make
Old 06-09-2016, 05:49 PM
TheDirtman's Avatar
I just replaced mine with the center force dual friction and their flywheel in my JK. Put the dual friction clutch in my JKU about 4 years ago with the factory flywheel. The center force flywheel is 20lbs heavier which should help at low speed to prevent stalling but I can feel a loss of power going up steep grades on the highway.
Old 06-09-2016, 06:14 PM
rd0t's Avatar
Do you remember which kit you purchased? I'm checking out the Centerforce website, but it looks like all the kits need the Centerforce fly wheel?
Old 06-09-2016, 08:19 PM
TheDirtman's Avatar
You don't need to use the center force flywheel only a new OEM or have your resurfaced.
Quick Reply: 2012 JK Clutch Options?
