2013 brake booster
Not sure where to post this so feel free to move it.
On my 2013 Rubicon brake booster there is a Bosch module coming out of the booster that has a gray connector on it. I can unplug the gray connector but I wonder if the Bosch module just pulls out of the booster or is there a release somewhere on it? I need to get it out of the way for an air compressor install. It is the only way this thing is going to fit.
It just pulls right out. There's a barbed fitting, so you may have to wiggle it a bit, but the sensor will pull right out of the hose and the hose and fitting will pull right out of the booster.
Just be sure to make 100% certain that there is no vacuum leak when you put it back together otherwise your brakes will work like crap.
