265 vs 285 Is there much difference?
Old May 26, 2014 | 08:00 AM
miraclemax's Avatar
Default 265 vs 285 Is there much difference?
so i own pretty new (80% tread left) 265/75/16 nitto terras right now on my stock 16 steelies
I have a chance to get some used (55% tread left) 285/75/16 nitto terras for a good deal.
Should i do it? or just save my cash for new "real" 33's?
Is there enough difference between the two tires to even tell?
Old May 26, 2014 | 08:11 AM
eclipse3319's Avatar
Just save your money it'll be more worthwhile
Old May 26, 2014 | 08:28 AM
JK_Convert's Avatar
Agreed. Your tires are fine don't waste money on new ones.
Old May 26, 2014 | 08:31 AM
sillybubba's Avatar
+1...the tires you put on will be almost exact....just 20mm wider (less than an inch) unless you love the look of the tire, or you are getting a CRAZY deal....just keep what you have....
Old May 26, 2014 | 08:33 AM
sillybubba's Avatar
just re-read...the 'new' tires are the same make as the old.......just save your money.
Old May 26, 2014 | 11:16 PM
Bypass's Avatar
If you can trade for something other than Nittos then you'll be doing some good.
Old May 27, 2014 | 03:54 AM
Hot94Z28's Avatar
I think you should buy my tires I see you are from the Midwest and I am selling 285/75/16 wheels and tires sounds like you might be the guy that's been texting me.
Old May 27, 2014 | 04:04 AM
Hot94Z28's Avatar
The difference is 31.6 inches tall X 10.4 inches wide vs 32.8 inches tall X 11.2 inches wide. Is it enough to give you the look you want? Also if you really like the nitto's you have then you know how the tire is. I went to 35's with about the same jump in size and the look is all the difference in the world.
