275/65 r18
Old May 28, 2013 | 04:30 AM
Pancho's Avatar
Default 275/65 r18
Has anyone mounted 275/65r18 tires on a stock sahara? If so did you experience any rubbing?Thanks
Old May 28, 2013 | 07:05 AM
Morris4x4Center's Avatar
Sponsoring Vendor
33.2x10.8/18
Usually anything wider than 10.5" wide will rub.
Old May 28, 2013 | 07:26 AM
PG-JKU's Avatar
I had this size of Duratrac on my stock Sahara. Rubbing on the swaybars at full lock. Otherwise fine.
Old May 28, 2013 | 09:00 AM
Bevo10's Avatar
Would spacers be an option?
Old May 28, 2013 | 09:13 AM
BlackRockBurner's Avatar
Adjust your steer stops so there's no rub on the control arms; trim / remove front air dam if there's contact; or install quality wheel spacers. I ran 275x70x18s and had to adjust the steer stops, later I installed Spidertrax wheel spacers. With a wider track, the jeep handled turns flatter and looked much better.
Old May 28, 2013 | 09:35 AM
2013-JeepJK's Avatar
Originally Posted by Morris4x4Center
33.2x10.8/18
It's actually a 32.1" tire... It will not rub.
Old May 28, 2013 | 07:26 PM
Pancho's Avatar
Thanks for the info!
