285/70/17 km2's on rubicon
Old Mar 20, 2009 | 06:47 AM
jeepnick's Avatar
Default 285/70/17 km2's on rubicon
hey im looking to put 285/70/17 km2's on my rubicon going to try to avoid the lift cause then i would want 35's and dont want to regear, what size wheel spacers would i need 1inch or 1.5? going to be on 17inch xd hoss 795's or would 35's be alright with the 4.10 gears with a 2.5 lift?
Old Mar 20, 2009 | 07:14 AM
Calypso's Avatar
What is the back spacing on the XD's? You probably won't need wheel spacers with them or most aftermarket wheels.
35's would be fine with a 2 1/2" lift with you stock 4:10 gears. You would notice a loss of power at 70 + mph and in hills but not too bad. If you you have a manual, it would be even better.
Old Mar 20, 2009 | 07:18 AM
jeepnick's Avatar
it is a manual there isnt much anyway upwards of 70mph
Old Mar 20, 2009 | 07:25 AM
Calypso's Avatar
Then go with the lift and 33's or 35's or you will just wish you had.
Old Mar 20, 2009 | 07:42 AM
jpp's Avatar
jpp
Lot of guys here running 33's with a Buget Boost. Works out to be a great combination and doesn't change the drivability much over stock -if at all.
We put that combo on my Dad's 4door with the stock wheels. Only required a small adjustment to the steering stop to prevent rubbing at a full turn, and his tires are FAT. Looks great, didn't hardly affect the performance and he is running 3.73:1. It would be even better with 4.10:1
Old Mar 20, 2009 | 08:02 AM
1JK's*'s Avatar
You do not need a lift to run the 285/70/17 (33's). I ran 33's on wheels with 4.5" of backspacing and no lift with no problem. I ended up putting on the 2.5" lift and love the combo. As far as the spacer, I agree with the post above. It depends on the backspacing of the new wheel. Stock is 6.25" of backspacing. Most aftermarket rims are 5" or less. You would not need spacers with a rim of 5" of backspacing or less.
