2DR Drive Shaft on 4 Door
I have a 07 4door Unlimited with a 4" Pro Comp Lift. The front drive shaft has expired. I found a new take off from a 2016 2DR.I called the dealer and the part numbers are different, but does anyone know if it would work? It's only $50. Thanks in advance for any help.
https://www.jk-forum.com/forums/stoc...estion-288892/
There's a bunch of differing part numbers for the drive shafts. I think (but am not sure) that the fronts are the same. The rear 4 door is longer than the rear 2 door.
