2nd Red Top Optima Battery EXPLODED!!!
Old Jun 7, 2007 | 12:32 PM
bleblanc's Avatar
Default 2nd Red Top Optima Battery EXPLODED!!!
Thats right!! There must be a bad batch out here. When I took it in today down to the shop, they said that it's the 4th one in the last 3 weeks. So I had them exchange it for a Yellow Top and hopefully there won't be any problems here on out.
So for any of you that just bought a new Red Top Optima Battery, and start noticing an odd/sweet/nasty smell that gives you an unbelievable headache; open your hood CAREFULLY and look to see CAREFULLY if the battery is leaking acid.
Hopefully nobody else has these problems. So far there is at LEAST $2500 in damage according to the estimate the dealership gave me.
Old Jun 7, 2007 | 12:55 PM
4JEXEP4's Avatar
So who is footing the bill for the damage??
Old Jun 7, 2007 | 12:59 PM
bleblanc's Avatar
We had to send both batteries to Optima for their engineers to "look into it." They said it could take up to 6 weeks before I even hear anything back. Sucks because my poor Rubi's paint is just bubbley all over the passanger side.
Old Jun 7, 2007 | 02:02 PM
usmcdoc14's Avatar
have you had your regulator/alternator checked?
Old Jun 7, 2007 | 02:12 PM
bleblanc's Avatar
No, why?
Old Jun 7, 2007 | 02:15 PM
usmcdoc14's Avatar
No, why?
because you are overcharging and cooking batteries thats why
when Optimas or other gel based batteries are overcharged the gel separates from the plates in a hydrogen bubble and then BOOM (or pop).
I thing your regulator is screwed, bring to dealer.
Old Jun 7, 2007 | 02:23 PM
bleblanc's Avatar
I don't think thats the problem because 3 other Red Tops have exploded in 3 totally differant jeeps out here. The other 3 are not JK's.
Old Jun 7, 2007 | 02:25 PM
4JEXEP4's Avatar
That is not what the problem is I am pretty sure of that. Considering 3 other Red Tops have exploded in 3 totally differant jeeps out here. The other 3 are non JK's.
It would be good to have it checked anyways. If it is the alt. then its the dealers problem and you may have a fix sooner than 6 weeks.
Old Jun 7, 2007 | 02:29 PM
bleblanc's Avatar
Yea, you both have a good point! I need to take it into them anyways cause my rear locker light is blinking from the last trip. I figured it may because of the battery, but it's still doing it after this new one has been put in. Only problem is, I won't be able to for at least another week or two.
Thanks for the replys guys!
Old Jun 7, 2007 | 06:56 PM
Zylfrax791's Avatar
Everyone told you not to run the Warn Powerplant off a Optima Red Top in your other thread when you blew up your first battery. So you went and did it again? Maybe you need to start thinking about a dual battery setup with an isolator instead of blaming Optima. Having your alternator checked is also a good idea.
