2wd to 4wd conversion help!
#21
Sponsoring Vendor
#22
Found a transfer case adapter.
Now i need
Front Axle with 4.10 gears
F&R drive shafts
May have found a transfer case but let me know if you have one! I can order everything else
Now i need
F&R drive shafts
#24
#25
#26
If you've done this what parts NEED to go in before others? Such as the shifter cable goes in before the t-case. Any tips help! Hope to have this finished before July
#29
i also did the conversion... worth doing not that big of project. like someone else said the hardest part was getting all the parts together.. but sounds like you have that taken care of.. good luck
