2wd to 4wd conversion help!
Old May 5, 2013 | 03:01 PM
JK yeti's Avatar
Default 2wd to 4wd conversion help!
About to start this project on my 07 JKU.
Making a parts list and just trying to double check everything!
1. Front axle with 4.10 gears
2. Front & Rear driveshafts
3. Transfer case
4. 4wd shorter tailshaft
5. Shorter adapter for transmission to T-Case
6. Cross Member tranny mount
7. 4wd shifter
8. 4wd shifter cable
9. Tail housing
10. Tail housing mount
11. Input shaft
12. Tail housing cable bracket
13. Shaft clip
If you've done this or know anything about it let me know if i missing anything! Thanks!
Old May 7, 2013 | 11:12 AM
grizzwald's Avatar
How did u end up with a 2wd jeep?
Old May 7, 2013 | 11:13 AM
1995nscajeep's Avatar
You ll need 4.10s for the rear my guess since its 2wd it don't got them
Old May 7, 2013 | 11:21 AM
jk_sea's Avatar
I think it's a noble effort, but wouldn't it just be cheaper to sell your 2wd Jeep and buy a similar one in terms of year/mileage with 4wd?
Old May 7, 2013 | 11:32 AM
RustysTech's Avatar
Sponsoring Manufacturer
Rusty's Off-Road
They made a limited run of the 2WD version for a number of years. Jeep stopped a couple of years ago.
Old May 7, 2013 | 11:33 AM
Rocky Clymer's Avatar
ditto - isn't worth the trouble...sell it and get a used or new one already set up.
Old May 7, 2013 | 12:27 PM
horrocks007's Avatar
I know there is a thread on here about it, I'm just too lazy to find it for you.
Good luck with your project!!!
Old May 7, 2013 | 06:50 PM
jaker t5's Avatar
And you this how
Old May 7, 2013 | 06:59 PM
jaker t5's Avatar
3. Transfer case
7. 4wd shifter
9. Tail housing
11. Input shaft
13. Shaft clip
I don't know if you made this list before I talk to you , but a lot of the stuff on you list is the same things
# 4 , 9 and 10 take off your list
Here is some pictures of the adapter and adapter mount
The bracket to hold the cable on the adapter
Last edited by jaker t5; Jun 2, 2013 at 04:18 PM. Reason: No Eddie but still no links allowed
Old May 7, 2013 | 07:02 PM
jaker t5's Avatar
Maybe if you can find a 4wd and only have to pay between 900 to 1500 difference
I converted mine and my total cost after upgrades was 1800
