3" or 4"
Old May 11, 2009 | 05:01 PM
silverfreak's Avatar
Default 3" or 4"
so besides drive shaft issues...will i encounter any other drivetrain issues if i decide to go with a 4" instead of a 3" lift???
Old May 11, 2009 | 05:20 PM
mkjeep's Avatar
If you have an auto, you'll have probs with both the 3 and 4in hitting your trnny pan,crossmember/skid. Rear, no probs.
Old May 11, 2009 | 05:27 PM
yeah i kinda figured that...but any difference bw running the 3 and 4...is there anything that will wear quicker by going the extra inch..
Old May 11, 2009 | 05:31 PM
mkjeep's Avatar
Only your stock frt DS. With 3in it's at a bad angle, 4in really bad angle on the upper joint. Plus, members on here with budget boost have torn that boot on the ds. So really, that's the main wear out, change out part.
Old May 11, 2009 | 05:38 PM
mkjeep's Avatar
Now this is my experience, so take it for what it's worth. I've noticed no other part besides the ds and I changed it out after adding adj frt lowers to my lift . Berfore I had a BB and then went to a 4in Superlift.
that's what i was wondering...thanks
Old May 11, 2009 | 05:41 PM
mkjeep's Avatar
No problem, you might wanna check out some rides with La4x4 in the Baton Rouge area.
