3.6 cat back system...suggestions??
Old Dec 18, 2012 | 02:59 AM
  #21
bushpilot's Avatar
Originally Posted by dognights
Ok so with a bit of work you should be able to make the AFE fit your 2 door just fine. I have heard both up close and the 3 inch just sounds way better then the 2.5 inch tubing is all. it is a deeper sound and doesnt sound ricey at all. The muffler you are putting on is what is causing your back pressure the size of the tubing really is just giving you the resonance after that really. I welded my new exhaust on and honestly I had to trim a few inches off on my 4 door to make everything fit up nicely and sit on the stock hangers nicely. The 2 door im sure you could make it fit just fine if you are even semi handy with a cut off wheel and then clamp or weld it all up.
There are plenty of other options but most all regardless of who makes them will need a bit of love to make them fit perfect no matter what.
seriously ?? if i spend 300+ on something i dont want to have to modify it to fit !
are the hangers even in the same locations from the 2 to 4 door ?
hell if i have to cut and weld something thats off the shelf - ill go have a system custom bent for a hell of a lot less !
Old Dec 18, 2012 | 04:37 AM
  #22
rockrail's Avatar
They do make them for the 2 door, both 2.5 inch and 3. inch
2.5 inch which I have on my 2 door:
Exhaust Systems CAT-Back aFe Power MACHForce XP 2.5in Cat-Back SS-409 Exhaust Systems; Jeep Wrangler 12-13 V6-3.6L (2 Dr) 49-46214 - aFe Power
3 inch
Exhaust Systems CAT-Back MACH Force XP Exhaust System;*3in Cat-Back 409 SS;* Jeep Wrangler 2 Dr;*12-13 V6-3.6L 49-46213 - aFe Power
Old Dec 18, 2012 | 11:29 AM
  #23
bushpilot's Avatar
thank you !
Old Dec 18, 2012 | 05:30 PM
  #24
dognights's Avatar
I would say be prepared with ANY system you buy to need to cut a bit or bend some to make it fit perfect. Looks like someone posted up the 2 door system might wanna give that a try. I think you would have a really hard time finding someone to build you up a full stainless 3 inch system from the resonator back up over the axle with attachment to the stock hangers for anywhere near what you would pay for one of these systems.
