3.8 pinging
Originally Posted by itsajeepthing91
It seems to happen intermittently at wot. It gets worse under load. I haven't noticed any power loss.
I was under the impression only the automatic transmission controller had adaptive programming.
What's on the outer ring of the torque converter that would monitor torque?
Ok guys with this pinging noise listen up! I had the exact same thing with my 2010 jk 2 door around 16,000 km. it started out only doing it when it was really hot and under load, also I have a 6 speed, so I did all kinds of stuff and the only thing that made it go away for a short period of time was better gas but it didn't really go away. I have a very good realationship with my dealer do I asked them about it and they had me get it really hot and take one of there techs for a drive and he heard it and said that's an easy fix! I said ok fix it lol he told me they need my jk over night and so I left it with them, the next day after work went and picked it up and it sounded like new again, I didn't get the full story of what they did but they said it was carbon build up and they had to fill the intake with something and let it sit over night and soak down, then start it up and hold it at 4500 rpm from cold till it was done a full cycle, which I think means goes into open loop? But my jeep was perfect for about 15,000 km and now it's back, and to the one guy asking about power loss, if you couldn't here the noise you would never notice a difference, these motors are dirty, just pull off your throttle body and look at the back of it and you will see what I meen, call the dealer and ask about the procedure I just talked about, I will call my buddy at my dealer tomorrow and find out exactly what they did and what they used , try pulling the air box and using a good throttle body cleaner and see if it makes a difference, hope this helps man it's not a nice noise for a $30,000 + truck that we are still paying for
Cheers: Dylan
Cheers: Dylan
Originally Posted by bubba_zenetti
You guys know that if you drive it around pining for around 500 miles you would have melted holes in your pistons by now? Your spark plugs would be blistered white on the cylinder(s) that are pre-igniting? Never on WOT? And sad to say, oil consumption and pre-ignition have no correlation with each other. But if you care to explain to me how that would be the case I am all ears. Lets see these documents. If anything a motor consuming oil will have less compression so it is less likely to detonate or pre-ingtite.
Makes no sense guys..............
Take the heat shield off your drivers side manifold for shits and giggles. Humor me please.
Like I said, mine sounded like a small hammer hitting the manifold. It came and went at random. It might not be the issue at hand but none of what you guys are grasping at outside of carbon buildup is a factor and even so, there are elements that even rule out carbon as an issue.
Cheers: Dylan
Cheers: Dylan
