3.8 pinging
Originally Posted by jeep_creep
Anytime, I just wish I got more info on it so I can do it myself and mabey find a way to prevent it. Keep me posted on what you find
Yea mine sees the rev limiter all the time and it has intake and exhaust and I love the sound of it so it gets opened up Everytime I drive it lol
Seriously... my first thought was why would someone install a CAI and opened up the exhaust without installing a tune? or did you forget to say you did that?
I always thought timing, higher compression ratios (10:1 and above) and cheap fuel (low octane) contributed to pre-ignition. And if the combustion chamber got hot enough it could diesel (run on) when you turned off the motor ... because that's how diesels work. Lower grade fuel, high compression ratio and high heat makes it "run-on" like a diesel is designed to function. Without spark to ignite the fuel...
So, if you run some fuel system / injector cleaner through your tank that was suggested a few times, you might fix the root cause, like maybe cleaning some dirty injectors and carbon that may be contributing to your problem... again, try Chevron Techron or its equivalent. Maybe the BG44k stuff will work like a charm - what do you have to lose? Just pour it into the gas tank...
Start from the ass-end and work up is my motto...
.02
Originally Posted by m998dna
Good idea m998dna... I think I'll try that myself.
.02
Originally Posted by bubba_zenetti
Pre-ignition WILL melt holes in pistons in very short time. The fact that everyone is driving around with this sound and no one has melted a piston of done some sort of damage like crack a ring land is pretty amazing.
It does not take long for pre-ignition to cause damage. Especially on an engine with cast pistons.
No loss of power and its pre-igniting. There is no way. Pre-ignition will trigger knock retard events that will pull timing out. This will create power loss. Pre-ignition also casues power to drop shaprly from the event itself as proper combustion is not happening and you are having 2 spikes in cylinder pressure at the wrong times. If you are getting pre-igntion events it will cause a drop in power you can feel.
Even if you buy mule piss for gas, that ethanol they add to it has a knock resistance of around 110 octane. Believe me it is not due to poor gas quality. Modern vehicles are tuned for the lowest common denominator.
If this is something that is happening only to 6 speed guys, all I can say is you may be lugging the motor if all else checks ok.
Originally Posted by itsajeepthing91
How can you be lugging the motor at high rpm? I'm sure the tires don't help but I just can't see that being the reason
I said a couple of times that I put a bottle of sea foam in my current tank of gas. Sea foam can be used to clean injectors. I have a superchip but I have only ever used it for diagnostics and speedo recalibration. Whenever I run a tune with it I get major pinging.
So why would you install a CAI and open the exhaust and not recalibrate with a CMR tune? I don't understand.
Your above statement is a good clue that you get pinging when you load a tune... what tune? and what octane gas is it programmed for?
Maybe you need to take it in for a PCM flash at the dealer... take the CAI off and get back to basics. That shit doesn't do much for your 3.8 other than make more noise.
Good luck.....
This is what I read in your first post >> "Still pinging than I tried seafoam down the brake booster line..... Seem to have noticed some difference but still pinging."
Good luck.....
If you've ruled out poor gas and you've cleaned your fuel system then the next step is run a full diagnostics and review for failing sensors .... I think your wasting time posting in this silly thread and getting everyone riled up over what the problem could be. Simple, run a diagnostics and be done with it... hone in on a failing sensor or faulty ECU.
Again... good luck.
