3.8L Engine Build
Old Feb 4, 2011 | 11:15 AM
  #51
ronjenx's Avatar
Originally Posted by BKGM Jeepers
how could 5w30 oil solve the problem? That is a thinner oil than the factory spec? I run syn blend in my 08, but will go to full synthetic when I cross 10K miles. I have one of the "lifetime powertrain" jeeps and want to keep that warranty. My local dealer was fine with runing the blend and full synthetics. Not sure about weight however...
Factory recommendation is 5W-20. You're saying 5W-30 is thinner than 5W-20?
Old Feb 4, 2011 | 11:37 AM
  #52
קובי's Avatar
Default שינו למנוע אמי 6.1
בירצוני לבצע שינוי למנוע אמי 6.1
ותיבת הלוכים אוטומתית
רציתי לקבל את רשימת החלפים הדרושה לשינוי זה
Old Feb 4, 2011 | 12:26 PM
  #53
AZJeeper's Avatar
Community Favorite
Well said!
Old Feb 4, 2011 | 12:30 PM
  #54
ronjenx's Avatar
Originally Posted by AZJeeper
Well said!
I was trying to come up with something clever.
I applaud you!
Old Feb 4, 2011 | 01:09 PM
  #55
anyone know what language that is?
Old Feb 4, 2011 | 01:33 PM
  #56
nthinuf's Avatar
Looks Israeli?
Old Feb 4, 2011 | 02:08 PM
  #57
RIPPMODS's Avatar
Sponsoring Manufacturer
Originally Posted by MuleShoer
Three years ago with Jeeps, same thing. We tried Amsoil, Redline and Mobil, we found oil consumption over 3000 miles. We switched to GTX 10/30 and the oil consumption was nearly gone...
RIPPTECH
Are you saying that standard oil is preferred over the Synthetic's?
I switched to Castrol's Synthetic's in the anemic 3.8 figuring it would not breakdown because of the increase operating heat. I always used synthetic in the race cars, close tolerance , high heat, etc
The real question is why are these engines using oil? Is it cylinder washdown into the combustion chamber? Are these engines really tight tolerance? or the opposite.
We think the 5/30 is just to thin - because there is no consumption with the marginally thicker oil... Some engines are sloppier than others and it just seeps through the "cracks" - plus your always stepping on the gas revving it out to get you over every little hill... We noticed with the blower there wasn't any more consumption - However these engines do run sloppy on the crank-case side so it could just be sucking it up through the vents rather than consuming it We are actually testing with catch cans right now to prove our point - more on that later this year.
Interesting alternative. I have an 08 with about 4K miles on it used mainly off road. I live in CA and wondered about any chance of a CARB exemption to run it?
We send at least 10-15 kits a month to cali, our kit comes off in 20mins tops - sooo doesn't seem to be a problem (officer)
If you tried Amsoil and Redline before ending up with Castrol, did you try Royal Purple? Just curious? I've had great success with it.
No - we didn't but we suspect its not the oil - per-say - We think its just a bit sloppier thats all... Our 60k engine has not lost compression and neither has our 30k, so we feel their running soundly using 1/2 quart per oil change.
So as you can see the theory of relatively is clearly spelled out above with 6.1 being the denominator.
RIPPTECH
Old Feb 4, 2011 | 02:23 PM
  #58
Jeep Hound's Avatar
worms.. you need earth worm jim to read this
Old Feb 4, 2011 | 03:03 PM
  #59
JK20A3's Avatar
Haha lmao!!
Old Feb 4, 2011 | 04:30 PM
  #60
backwoodjk's Avatar
I believe it is Hebrew.
