3" coilsprings and stock control arms
Old Feb 5, 2012 | 05:50 PM
Njjkrat's Avatar
Default 3" coilsprings and stock control arms
Any thoughts on this setup I found a set of teraflex 3" coils for a good price,I already have adjustable track bars front and rear and probably going to install the aev drpped control arm brackets till I can afford some adjustable arms,Thanks any input would be helpful.
Old Feb 5, 2012 | 06:02 PM
mkjeep's Avatar
I ran 4in superlift springs on stock CA's for quite awhile. You can do it provided your shocks, swaylinks , bumpstops,brakeline ext are correct already. I'm assuming your running some type of lift now?
Old Feb 6, 2012 | 02:38 AM
Njjkrat's Avatar
Right now I'm running a 2.5 teraflex coil lift , I'm also getting the sway bar links and shocks from the 3" kit.
Old Feb 6, 2012 | 04:13 AM
Saharaunlmtd's Avatar
I ran the 2.5 TF spacer lift then changed the front to the 3" springs. I didn't really notice any worse handling but I eventually got longer lca's.
I considered the AEV drop brackets but they are made for a 3.5-4.5" lift. I found out afterwards that the TF 3" springs give more than 3".
