3" coilsprings and stock control arms
Any thoughts on this setup I found a set of teraflex 3" coils for a good price,I already have adjustable track bars front and rear and probably going to install the aev drpped control arm brackets till I can afford some adjustable arms,Thanks any input would be helpful.
I ran 4in superlift springs on stock CA's for quite awhile. You can do it provided your shocks, swaylinks , bumpstops,brakeline ext are correct already. I'm assuming your running some type of lift now?
Originally Posted by Njjkrat
Right now I'm running a 2.5 teraflex coil lift , I'm also getting the sway bar links and shocks from the 3" kit.
I considered the AEV drop brackets but they are made for a 3.5-4.5" lift. I found out afterwards that the TF 3" springs give more than 3".
