3 inch lift recommendations
Old Oct 4, 2012 | 08:31 AM
jb0974's Avatar
Default 3 inch lift recommendations
I am looking at 3 inch lifts for my 2010 jk unlimited for under $1000. Any suggestions? I am leaning towards the Rancho 3 inch stock mod and adding control arms later. Any suggestions would be greatly appreciated.
Old Oct 4, 2012 | 08:34 AM
wayoflife's Avatar
JK-Forum Founder
the rancho kit is a good one and really, hard to beat for the money. i would definitely recommend it.
Old Oct 4, 2012 | 10:04 AM
jb0974's Avatar
Thanks. Would you recommend it over the Tereflex 2.5 inch kit? From what I read the Tereflax 3 inch kit will require a new driveshaft not needed with Rancho. I wo uld like to get as much lift as possible without driveshaft modifications.
Old Oct 4, 2012 | 10:17 AM
immortalmetal's Avatar
I would recommend the teraflex 2.5 w/ at least the shock extensions.
Old Oct 4, 2012 | 10:23 AM
jb0974's Avatar
I am purchasing Billstien 5100 shocks (and adjustable tracbar if I go with Teraflex). how much lift will Tereflex 2.5 give me? I have bumpers, 315 Duratrac spare/17 rim and rock rails
Old Oct 4, 2012 | 11:29 AM
TeraFlex's Avatar
Sponsoring Manufacturer
What size of tires are you considering?
Old Oct 4, 2012 | 11:39 AM
jb0974's Avatar
I have Goodyear Duratrac 315/70 17R, bushwacker flat flares
Old Oct 4, 2012 | 11:47 AM
smirak's Avatar
My TF 2.5 kit netted me 3 3/8 in the front and a little shy of 3 in the back. I don't have aftermarket anything 'cept wheels/tires.
FYI
Old Oct 4, 2012 | 12:06 PM
TeraFlex's Avatar
You can run either a 2.5" coil kit or a 3" TeraFlex kit. The 2.5" will raise the front 3.1", and the 3" will raise the front 4.25" on a stock JK. Generally I suggest the 3" for customers that plan on adding alot of weight to the JK. You do not have to change out your driveshafts with a 3" under a 2010 Unlimited.
Old Oct 4, 2012 | 12:24 PM
Rancho's Avatar
How hard are you going to be pushing your Jeep?
