3" Lift Problems
ok, i will try removing it. so without the track bar what will occur? my axle will not be centered? how will that effect ride? or do i need to remove and add a adjustable track bar? it is a little disconserning that they design the kit with this and it is not correct! or that they make a product that when installed is not correct and causes problems. i am new to lifts but this doesn't seem like a "true and complete kit" as they advertise, if the parts they supply don't correct driving issues.
I had the "holes don't line up" problem with my Full Traction kit as well. I drilled out the hole slightly till I could just get the third bolt to fit with some help from a dead blow mallet. Then I cranked everything down really well. I don't have any issues with mine. However, I am going with an adjustable track-bar ASAP to eliminate the bump-steer I have now.
-E
-E
every jeep is different. it's bizarre, but it's true. something that works on someone else's rig may not work for yours. an adj. track bar really is the way to go. you can pull your bracket now, and you will be a little off center, or just deal with the DW until the new one comes in.
remember, you'll be scared, but you are still in control.
JK-Forum Founder
What you have is a great 3" lift that is ready to be upgraded.
JK-Forum Founder
Like someone stated in another forum, the jeep is built within certain quality control limits. Lets say they range from -5 to +5 with 0 being the perfect. Anything that falls within that range is acceptable, safe, and built correctly. There is no way to know where in that range each component of your jeep is. Some jeeps come off the line at the 0, some more towards one of each end of the range, and some at the end of the range. This means nothing to someone who doesn't modify their jeep. It will function just as well as any other jeep produced that passed the QC.
Now, Fulltraction all produces their lifts with a control limit. So, they also have a range of -5 to +5. Lets say your jeep was at the -5 and the lift you got was at the +5. Both were considered Quality products by the company and the industry standards. BUT your holes didn't line up quite right and would need a drill run through them. Or you could have a little bumpsteer that others don't have, or death wobble, or etc.
Really, I agree that an adjustable track bar would solve the problem, and actually make the whole jeep better. The trackbar is a bargain at 179. I bought one for my truck and it cost me 250 and it wasn't adjustable.
Bryan
Bryan
I see your point of view and maybe i am just new to all this but i just still don't see how a kit can be designed "econo" or "Premium" or whatever. and not function correctly. if the relocation bracket is a budget fix, then it should fix the problem. whether it is budget or not otherwise it is not a fix and not working. the adjustible track bar is great, and i am forced to get one now, but as i understood things it is an upgrade feature that will let me dial in minor adjustments like weight compensation form winch, bumper etc. and yes perfectly correct this issue as i am understanding now. my issue is whether it is econo or ultimate it should be engineered to not have these drivablity issues. maybe i am expecting too much as a customer to have parts fit correctly and function as intended... or maybe this is an isolated instance. but an "Upgrade" should be just that an upgrade to better adjust or tune or improve something. not to Correct an issue the original part was faulting at.
either way i am just left unsatisfied and confused as a customer.
BUT HEY ITS A JEEP THING RIGHT!
I agree with the fitment issue, it seems like everyone I've talked to that installed this kit had to do some work to get the outboard hole on the track-bar relocation braket to fit. I doubt this is an issue of combined tolerances as a previous poster suggested, since it always seems to be the same bolt hole that everyone has problems with, and always about the same amount of error. If it was just tolerance issues, there would be an equal amount of complaints for ALL the holes not lining up. I've only talked to about 3-4 people aside from myself who did this kit though.
-E
This is the other thing to watch for when doing your research. No offense, but if you were to stop reading the above after "I don't have any issues with mine.", you would miss the fact that even though he doesn't think he has issues, the reality is that he does. He has bump steer. While he may not think it's a problem, others may read and get the feeling that a xx" lift can be installed with no problems. It may be something he can deal with (probably not since he is upgrading trackbar), but you may not like it.
JK-Forum Founder
