-30mm or - 19mm offset
Old Jan 14, 2014 | 05:51 AM
NCJohnP's Avatar
Default -30mm or - 19mm offset
Ordering 15'' trackers today. My question is which offset should I go with. I see most people have the - 19 offset, but I like the wider stance. Would the - 30mm offset cause that much more stress on components?
Old Jan 14, 2014 | 07:19 AM
Sebastian's Avatar
First off most people with aftermarket wheels have -12 mm offset not -19 mm. And that's alread too much in regard to tread coverage from your fender flare - your tread sticks out and that's illegal.
So -12 mm already gives you a significantly wider stance but you will get away with it most of the time. However -19 mm is getting a bit extreme and -30 mm is ridiculous in my eyes. It would be a matter of time until the 5-0 pulls you over with -30 mm. A trailer queen would be a different animal of course.
Old Jan 14, 2014 | 07:37 AM
AlexjeepVb's Avatar
I have the 15 trackers with -30 and love it. Think it looks right as gives it a good stance, not sure where you live but I don't have any problems with the law, and its def not "ridiculous" at least in my eyes. If you go to one of discount tires threads you will see that the -30 is the most popular option.
Old Jan 14, 2014 | 07:43 AM
7kings's Avatar
I've got the 15" Trackers on mine with the -19mm offset, and I can tell you with 12.50" Duratracs, the stance is plenty wide. The tires extend past my stock fenders by probably 1.5-2" on either side. I really like the look (this is before the 2" lift in the front):
Old Jan 14, 2014 | 07:46 AM
Sebastian's Avatar
An offset of -32 mm equals a backspace of 3.5" to 3.75" depending on the width of the wheel (8.5" to 9").
If a backspace of 3.5" to 3.75" is what the majority of JK owners are running then I shall stand corrected.
ID:	523604   Click image for larger version
Old Jan 14, 2014 | 07:52 AM
TheDirtman's Avatar
most people run a 4.5" bs wheel
7kings's Avatar
This is completely dependent upon the state in which you live; in Florida, only commercial vehicles are even required to have fenders or mud flaps (FS 316.252(1)).
AlexjeepVb's Avatar
I was referring to the majority of people running the 15x8 level 8 trackers not all together, I believe it is 3.625 or something like that which is a good amount of bs and tires will stick out past fenders but if you like the wider stance( like I do, and he said he liked that look earlier) than these wheels will work fine.
Old Jan 14, 2014 | 07:56 AM
AlexjeepVb's Avatar
Here is what mine look like front and rear.
Old Jan 14, 2014 | 10:26 AM
7kings's Avatar
Just FYI - although the wide stance is really nice, be prepared that you're going to be painting the side of your rig with dirt every single time the road is even a little wet. Not a big deal, but figured I'd pass it along...
