318?
Old Aug 28, 2008 | 08:04 AM
Mo-mud's Avatar
Originally Posted by White Fang
A lift dosent void the warranty? Well thats good news but I dont really understand how. A buddy of mine bought a new silverado and lifted it which killed the warranty.
I was just planning on swapping to a v8 cause I figured the lift would kill the warrenty. I wonder how well a stock 4.10 would turn a set of 33s. Or could I get away with regearing to 5.13 and still keep the warranty?
Warrenties only get voided partially in most cases. Like if you regeared and something happened to the axles. They might could try to say it was a direct connection to your modification and void that portion of your warrenty. This is the way I understand it.
But, on the other hand, I have heard that some dealerships go out of their way to not cover any modified jeep. So find a god dealer before you take in for repairs and such. IMO
Old Aug 28, 2008 | 08:56 AM
riverzendz's Avatar
Inspections, what passes and what doesn't, is all in who you know.
It may not be legal, but it may pass inspection...
Old Aug 28, 2008 | 08:59 AM
Ben Hedrick's Avatar
Originally Posted by RedneckJeep
Yall got yearly inspections up there? If so, you might wanna reconsider. It's not a legal swap to put an older engine in a new vehicle anymore. The engine has to be the same year or newer.
I have heard this too, but in Florida we have no inspection so how would they know?
Ben
Old Aug 28, 2008 | 10:40 AM
berg's Avatar
Sorry all. Old engine in new car doesn't go anywhere in the U.S.
That's Federal regulations.
Put a 318 in a JK and you now have an off road only vehicle that has to towed to where you want to wheel.
Quite honestly, I just don't see the need for all the horse power gains that so many are looking for.
Whats the point? If you want to go fast off the line or have a very fast top end why buy a Jeep?
Gears and all I can understand for the trail. But too much of these and it makes the Jeep impractical as a DD.
IMHO I wouldn't want a JK that was an off-road only vehicle. If I was going for that kind of toy there are many older less expensive Jeeps out ther to buy and modify.
But all of this is just my opinion
Old Aug 28, 2008 | 10:42 AM
jpp's Avatar
jpp
Legalities Aside, swapping one of the Magnum engines into a JK would be a daunting task. There are a lot more things to consider than just the cost of the engine. I believe the computing systems are different between the two and the Bell housing does not match up either. You would likely be looking at running an NV3500 tranny behind the Magnum. That is why I said it is a good swap for a TJ. Everything is compatible, similar to the Hemi swaps in the JK. I priced out having a used 360 swaped into my 03 TJ Rubi before I bought my JK. It was running almost $9,000 for a turn key swap. With the Hemi kits available now, you would spend nearly the same amount to have a Hemi over the Magnum, not to mention it would be a legal swap. Something to consider if you ever plan on selling your JK some day.
Old Nov 30, 2012 | 08:00 AM
Kojack's Avatar
thanks for the answer...I was thinking about this swap myself...not for speed or off the line...but towing power and extra grunt off road. I LOVED my 318 in my dakota 4x4 I owned...but if a 5.7 hemi swap is easier and just as cheap/expensive.....then the hemi is the easy choice. can we use the multi"tronic" hemi where it shuts down 4 cyl for crusing ?
Old Nov 30, 2012 | 08:03 AM
Locko's Avatar
From: Hawai'i, Miami , FL, Alaska, Tennesse..S America
I have a lift and several bolt ons, winch, bumpers, armor, etc.. and I been to dealers from Miami FL to Juneau Alaska, and nobody cancel my warranty... even that most dealers suck anyway.. lol
