33" Cooper STT tire pressure
Old Jul 13, 2007 | 10:38 AM
glwood6's Avatar
Default 33" Cooper STT tire pressure
For those of you running these tires, what pressure are you using for the street?
Installer had them at 45 psi, seemed a little excessive...
Thanks,
glwood6
Old Jul 13, 2007 | 10:47 AM
Txhrns08's Avatar
I Am Running Mine At 41 Psi
Old Jul 13, 2007 | 05:24 PM
GatorGreenJK's Avatar
Default Nice JK by the way,
I saw pics of your JK posted in the Show and Tell Jeep Green post.
https://www.jk-forum.com/forums/show...?t=2060&page=3
Here is Mine,
I assume you are asking about on the road tire pressure? I have 33 x 12.5 "D" rated tires, sidewall says 50 psi, I did the chalk test, Started at 50 psi and am now running at 26 psi, they feel better and the chalk proves they are contacting the ground evenly across the tread.
Have you chalked them?
Again I must say that GatorGreen JK of your looks GREAT!
Old Jul 13, 2007 | 05:41 PM
usmcdoc14's Avatar
45psi, 41psi HOLY FAWK !!! I am running 28psi in my radial claws, you seriously need to chalk test your tires
Old Jul 13, 2007 | 05:57 PM
Default Good advice
there is a link somewhere on this site on "how to chalk test".
Old Jul 13, 2007 | 06:05 PM
Robar's Avatar
Here is a good description of the "chalk test"
Originally Posted by usmcdoc14
there is not "simple" math as there are too many variables in tire/belts/whatever. Do a "chalk test"
1 piece of chalk, the kiddy sidewalk kind works well
a tire pressure gauge
a big parking lot with no cars and a nice strait run of say 500 feet
Drive around a bit to get the tires nice and warm and flexible.
get to one end of parking lot
aim vehicle across with the wheels strait
rub chalk across the entire tread of all 4 tires in a nice width as so you can find it.
drive forward, NO STEERING, for 500' or so.
stop
look at the chalk.
You will notice (almost 100% of the time the first time out) that the "center of the tread will have no chalk and the outers will.
deflate 5-10 psi
repeat until almost all the tread is wearing evenly.
My 35's are running 28psi all the way around and are quite happy
Old Jul 13, 2007 | 06:15 PM
usmcdoc14's Avatar
oh and it is much easier to feel in the handling of the vehicle if you have too little PSI, it will feel squishy/spongy. Its MUCH harder to tell when you have too much.
Old Aug 2, 2007 | 12:24 PM
ralphieboy's Avatar
On my unlimited Rubi, door sticker said 37 lbs for stock tires, after chalk test lowered to 26 lbs all was well. With my 35" Coopers, tire dealer put in 50 lbs, needless to say I was all over the road, after chalk, now running 24 lbs, all is well!!!
