33's Rubbin
Old Oct 21, 2011 | 01:12 PM
JnT's Avatar
JnT
Default 33's Rubbin
So I put a set of Duratracs (275/70R18) on my Jeep yesterday and have come to find out that I've got some rubbing at full lock.
What are my choices for fixing this (other than smaller tires lol)? Will a 1.5" spacer be sufficient? I will be putting a 2.5" lift on but don't have the cash for it right now....Just curious what is the best option.
Old Oct 21, 2011 | 01:15 PM
Battlefrog's Avatar
Wheel spacers will cure it..
Old Oct 21, 2011 | 02:00 PM
Cdash's Avatar
Or add a washer behind your steering stops...
Old Oct 21, 2011 | 02:06 PM
8000ft's Avatar
1.5" spacers will fix the rubbing as far as the sway bar is concerned BUT you will rub the center-upper-outer lip on the fenders at full compression.
Old Oct 21, 2011 | 02:23 PM
JnT's Avatar
JnT
Good to know. Shouldn't be a problem as the snow will be falling soon and I won't be doing much wheeling that will be flexing the suspension until after I get the lift put on. Guess I'll see what I can find for spacers around here.
Any recommendations?
Old Oct 21, 2011 | 03:55 PM
BigRich's Avatar
I did the RC 1.5" spacers. They are great, hub centric just like the spidertrax. Oh and I think they are only 59 per pair!
Old Oct 21, 2011 | 06:35 PM
85fr16's Avatar
I just bought a set of 1.5 Spidertrax on their website for $79 a pair. You have to look in the closeout section for the blemished ones to get them for $79 otherwise they are $99. You can't see any difference on the blems other than a scratch or scuff and they still have a lifetime waranty. Spidertrax are quality all the way from what I can see.
Old Oct 21, 2011 | 08:06 PM
09SDunlimited's Avatar
Spacers for sure. Cheap and if they are quailty and torqued correctly safe.
Old Oct 22, 2011 | 07:06 AM
JnT's Avatar
JnT
Sounds good. Thanks for the input guys!
Old Oct 22, 2011 | 09:59 AM
SebasCbass's Avatar
Originally Posted by JkJared
1.5inch spidertrax spacer
X2 on the 1.5 inch spidertrax... I just ordered a set of 285 duratracs and I will be running them on the stock rims because I like the way they look. I also had to get the spidertrax, and that should fix your issue.. Good luck
