33's and rubbing?
Old Apr 16, 2015 | 06:28 AM
jHaru's Avatar
Default 33's and rubbing?
Has anyone experienced any rubbing issues with 33x12.5 R18 on their JK with no lift. I am looking into buying aftermarket wheels and tires with a backspace of 4.5 to 5.5 inches. I had thoughts of a teraflex budget boost, but that may be something I do down the road.
You read so many different things. Currently I don't want to trim the fenders. Once again something I do down the road.
Anyone have any pictures of their 33's on their jeep.
Old Apr 16, 2015 | 06:49 AM
kodiak bear's Avatar
I put 33x12.5x17s on my JKU with stock wheels and suspension. It does rub taking tight turns and I'm going to be installing a lift and spacers within the next month or so, but they've been fine for everyday driving. I only notice the rubbing taking very tight turns, which I'm trying to avoid until I put the new parts on.
Old Apr 16, 2015 | 11:37 AM
wittys-jk's Avatar
Originally Posted by jHaru
Has anyone experienced any rubbing issues with 33x12.5 R18 on their JK with no lift. I am looking into buying aftermarket wheels and tires with a backspace of 4.5 to 5.5 inches. I had thoughts of a teraflex budget boost, but that may be something I do down the road. You read so many different things. Currently I don't want to trim the fenders. Once again something I do down the road. Anyone have any pictures of their 33's on their jeep.
Get some spacers it will fix your rub problem til you get your budget boost. Ran that way for about a year when I first got my jeep.
Old Apr 16, 2015 | 02:18 PM
Stinkfoot's Avatar
I had some minor rubbing at full turn on my 33's before i installed spacers, after that the only issue was when i poped off the rear fender before i got my lift installed, hit a culvert at speed which gave axle full flex and snapped the clips right off, fender went flying. Cost 3$ for clips to fix so no worries
Old Apr 16, 2015 | 08:01 PM
CerOf's Avatar
You will rub off-road. Small 33s with 4.5" back spacing and tore part of the fender flare: Click image for larger version
ID:	606711 these photos are with a leveling kit.
Sent from some string and a few tin cans.
Old Apr 17, 2015 | 02:37 AM
jHaru's Avatar
I appreciate the responses thanks. Those pictures right there explain it all.
Thanks again.
