35"s, no lift, but with flat flares?
Old Jul 16, 2009 | 08:00 AM
  #111
johnnyj33p's Avatar
Originally Posted by 08UnlimitedSahara810
I know someone with a 2 door JK that has 35's and flat flares. She had them custom made by a member of my Jeep club. They were very reasonable in cost. She has no rubbing at all with a stubby front bumper. PM me if you want the website for the flares.
Id like to see which flares they are if you could pm me.
Old Jul 16, 2009 | 08:20 AM
  #112
racer83l's Avatar
I added 35's to my set up 2 days ago. I will flex it tonight to its max with my hi-lo and see what kind of clearance I have.. some pics. and yes i lifted it, i needed ground clearance.
I think there is room for 37's
Old Jul 16, 2009 | 08:24 AM
  #113
westchester's Avatar
Originally Posted by Spillidge
It looks like the tires fit but what about flexing with the tires turned?
If you asking on mine, no problems when I trailed alone but I dont rock crawl. It must have rubbed slightly when drove in and out of ditches, but that was bearable, as is running it on the street. Only issues were when its weighed down.
Here's a side shot
Old Jul 16, 2009 | 08:30 AM
  #114
joey2times's Avatar
I have 35's with a 2.5 coil lift from TF with shocks.
I rub on the pinch and the rubi rail....
Flat fenders wont change that...
Gotta cut the rail or remove it
Old Jul 16, 2009 | 09:10 AM
  #115
tweba08's Avatar
That lift recommends running 35's and most people do. I trimmed my rubi rails back 2 inches and cut the pinch seam to match.
Old Jul 31, 2009 | 08:21 PM
  #116
rolly's Avatar
great thread!!!!
Old May 10, 2011 | 02:54 AM
  #117
98gp's Avatar
I like this idea.
Old May 10, 2011 | 03:32 AM
  #118
Harbourone's Avatar
I ran no lift and bushwacker flats and didn't rub anything...
Old May 10, 2011 | 04:05 AM
  #119
Was that before or after you added 1" spacers ?
To all on this thread, you will rub with 35" tires and no lift !!! The pinch seam DOES need to the trimmed or bashed clear, and the 35s WILL rub on the rear inside wheelwell frame when the suspension is flexed (deep pot-hole, wheeling off-road), and 35s WILL rub when have passengers and/or heavy gear.
Yes, 35s and no lift does work on smooth roads and only the driver.
There is just no getting away from it. We bought Jeeps to be capable off-road. 35s add to that capability but a 1" or better a 2.5" coil lift IS nescesary with 35s.
Rant over.
Old May 10, 2011 | 05:49 AM
  #120
Harbourone's Avatar
Rant over.
I ran tf extended rear bumpstops. I was incredibly close to the pinch seam but didn't touch it. The front cleared fine. But you're right, prior to the bumpstops in the rear I was rubbing hard on the inner fender.
