35'' yes or no
Old Jan 13, 2011 | 06:24 AM
fadeout's Avatar
GET um' you won't regret it one bit.
Old Jan 13, 2011 | 07:20 AM
highwayman's Avatar
Originally Posted by stevenm6626
i have to superchip and it works great. and no i dont have the 4.10 gears im not sure what they are i just know that they are way to high a gear ratio for crawling. and another thing i was wondering if anyone is running the poison spyder rock knockers and what they think of them.
ps thank for the input
Ill be running 35's this weekend. Have flatties & trimmed the rear pinch seam. Plan on running 4.88's soon, but from what Ive heard my 6speed & 4.10's are not too bad. Ill be throwing on my Teraflex 2.5 coil lift sitting in the garage after I get the last of the goodies in the mail (frt trackbar/rear trackbar & tearflex lowers). Im running the RockerKnockers & have been really happy w/em.
Attachment 117260
Old Jan 13, 2011 | 09:01 AM
jenly8's Avatar
I would highly recommend the lower gears. You will notice a huge difference with the new rotating mass
Old Jan 13, 2011 | 09:34 AM
Work in Progress - JK's Avatar
I have a 6 spd and 35's and Superchips programmer, I do notice a slight loss of power on the highway, but it's still very driveable. Will re-gear when i wear out my 35's and go to 37's with flat fenders - thats down the road tho!
Old Jan 13, 2011 | 09:55 AM
stevenm6626's Avatar
Originally Posted by planman
You may end up needing a 2" rear extended bumpstops.
You'll need either wheel spacers or aftermarket wheels with 4.75" or less backspacing.
Depending on your wheel backspacing, you may need to adjust your steering stops.
If you still have the front lower stock plastic air dam, you will need to trim the ends.
If you try to wheel in the rocks with 35s and 3.21 gearing, get used to a burning clutch smell. If you wheel frequently in technical rock terrain, you will end up frying the clutch and possibly the transmission if you wait too long to regear.
Sent from my DROIDX using Tapatalk
ya i am running the 3.21 gears but i will be re-gearing with the 35's and were would i go to get the 2'' bumpstop for the rear extention
Old Jan 13, 2011 | 11:23 AM
For the rear bumpstop extensions, you can buy a 2.5" Teraflex, or a 2" Full Traction from northridge4x4.com by calling David at the number in my signature.
Or, you can make your own with some 2" rectangular/tube steel cut to size, a drill, 4 bolts, and some spray paint.
i think ill try making my own ill let ya'll know how it goes and ill put up the pics as soon as i get back to the states
Old Jan 13, 2011 | 11:32 AM
Huntr's Avatar
I have 35s and 4:88s. After driving one with 5:13 I wish I would have went that direction instead. I have an automatic.
Old Jan 13, 2011 | 12:43 PM
Anaya's Avatar
With a 6 speed I think 4:88 are fine but with a auto 5:13 is what u need with 35"
Old Jan 13, 2011 | 12:55 PM
Howie's Avatar
I am running 35's on a stock suspension with bushwacker flats.....I love my 35's.
I haven't regeared yet. No real need to, just yet.
Old Jan 13, 2011 | 01:14 PM
HornetJK's Avatar
Having an automatic vs. a 6 speed is a big difference when regearing. Automatics are way more forgiving. With 35's he wants 4:88's or even consider 4:56's depending on driving habits and driving terrain.
