35's, 3:21's and an auto
Old Dec 24, 2011 | 02:16 PM
j33p4life's Avatar
Default 35's, 3:21's and an auto
anyone have 35 tires, 3:21 gears and an auto transmission? I know itd be horrible but anyone done it?
Old Dec 24, 2011 | 02:32 PM
j33p4life's Avatar
Originally Posted by planman
I believe 3.73 is lowest numerical gearing in an automatic. 3.21s are only available with 6 speeds.
3.73s with 35s is doable if you run a Superchips Flashpaq performance tune and always run with your overdrive turned off. On the highway, you'd run the same rpms as you would with 5.38 gears--which is recommended for Rubicon automatics with 35" or larger tires.
o really? haha I always thought that I had 3.21's thanks! do you know anyone that has it?
Old Dec 24, 2011 | 02:42 PM
ranjr's Avatar
What year is your JK?
Old Dec 24, 2011 | 02:49 PM
Delux2769's Avatar
I have 3.21 in my 6 speed. Very sad
Old Dec 24, 2011 | 02:56 PM
j33p4life's Avatar
2008.......
Old Dec 24, 2011 | 03:35 PM
Cervelo's Avatar
2012 JK auto 3.73 would still need the Superchip?
Old Dec 24, 2011 | 03:38 PM
ranjr's Avatar
2008.......
I do not believe 3.21 was available with the auto in 2008 and it should have 3.73s. You can run 35s with the 3.73s but O/D will be useless on the interstate.
Old Dec 24, 2011 | 03:43 PM
ranjr's Avatar
Well this isn't true since there isn't a tuner available for the 2011s and up yet. Also the 5 speed auto has an O/D ratio closer to the manual so the '12 with auto & 3.73 is geared like the 4 speed auto with 4.56 gears.
There have been several 2012 auto owners with 3.73s run 35s and report that re-gear really isn't needed.
Old Dec 24, 2011 | 03:47 PM
nthinuf's Avatar
No, you don't 'need' a tuner with any specific engine/tire combo. The added hp/torque/shift points/functions/etc can be very nice to have though, depending on what you have and your personal tolerance.
But, you will definitely want some way to recalibrate for the taller tires. Whether that is a programmer (ProCal) or a tuner (Superchips, Hypertech, etc), is up to you. With an Auto, if you can swing the added money for a tuner, it is the better way to go.
Old Dec 24, 2011 | 04:02 PM
j33p4life's Avatar
ok cool! thanks! I think I'll try it and just watch my speed till I get money for a programmer!
