35'S No lift?
It helps with fuel mileage. You can just pitch it and loose 1~2 mpg more than you otherwise would, or trim the back corners some.
Sounds like the best way to go is just trimming the air dam to not lose MPG, right?
Sure. Trimming air dam can be done, but it will probably be ripped off when offroad somewhere down the future. I saved that and chucked it away when put 35s on. Unfortunately, low MPG is a way of life with Jeep, but luckily is the only negative
