35's...regear?
Old Apr 28, 2014 | 11:27 AM
bmartin4's Avatar
Default 35's...regear?
I am looking into getting 35's mainly for clearance, but also because I think they will look better in an 18" rim currently holding 275/70's. My question is...will I have to regear?
Old Apr 28, 2014 | 11:33 AM
Mark73's Avatar
What gears auto ? Stick ?
Old Apr 28, 2014 | 11:47 AM
Mangrove Mafia's Avatar
What motor do you have? What terrain do you drive on?
Old Apr 28, 2014 | 01:25 PM
Ryan0260's Avatar
Need more info. Year, tranny, and gear ratio. Also, do you have a lift so you can clear 35's?
Old Apr 28, 2014 | 01:48 PM
suprablaski's Avatar
"Have to"? No. Want to? Maybe
And as others have stated it depends on year and tranny
Old Apr 28, 2014 | 02:56 PM
nthinuf's Avatar
... and location, and usage, and personal opinion.
This is one of the many questions that is asked just about every single day, so there are a ton of threads to read through for more info and opinions. But you could start by opening the Faq's at the top of this modified area and plugging some numbers into the charts to start getting a better idea and maybe put the advice you will get into better perspective.
Old Apr 28, 2014 | 04:19 PM
bmartin4's Avatar
I have a 2009 Jeep Wrangler Unlimited. It is a V6 Automatic Transmission. It has the stock gears in at the moment and it has a 4" lift.
It is my daily driver, but I do a lot of off roading as well. I mainly want the bigger tires so I don't have to worry as much about clearance in the trails.
Old Apr 28, 2014 | 04:36 PM
nthinuf's Avatar
3.8, auto, 4door, 35's - 5.13's are very popular. Some people close to sea level with no hills like 4.88's. And some (with d44 front axles) like 5.38's.
Plug some numbers into the chart to see where you will be. Use actual measured tire height, not mfg spec, and you will need your current gear ratio. Stock gears could be 3.21, 3.73 (or 4.10 for a rubicon), so if you don't know what you have, you might want to find out. Either email for a build sheet, or lift a corner, spin the tire and count driveshaft revs.
What you may want to do, though, is just get the tires and drive it and see what 'you' think. If it's too gutless on the freeway, press the OD Off button. (and if you want to get an idea of what that does -- get the rpms on the chart for your current gears and the new tire size, then just divide what you get by .69)
Old Apr 28, 2014 | 04:38 PM
planman's Avatar
Forum Tech Advisor
Originally Posted by bmartin4
I have a 2009 Jeep Wrangler Unlimited. It is a V6 Automatic Transmission. It has the stock gears in at the moment and it has a 4" lift. It is my daily driver, but I do a lot of off roading as well. I mainly want the bigger tires so I don't have to worry as much about clearance in the trails. Sent from my iPhone using Tapatalk
Then, you have 3.73 gears.
Your OD will be pretty much useless. However, if you turn it off on the highway and just run in 3rd gear, you will turn the same engine RPMs as you would with 5.38 gears.
If you run a Superchips Flashpaq tuner with the Towing tune and turn off the OD button every time you get into your jeep, it should be bearable with 35s.
Your around town fuel economy won't be great, and offroading, it won't be very good in slower, more technical terrain.
Old Apr 28, 2014 | 05:05 PM
bmartin4's Avatar
What are some good gears that I could get for a pretty cost effective price? The tires are already gonna kill the wallet, but one without the other sounds like it will be pretty useless.
