35's on stock suspension
Old Oct 24, 2010 | 09:26 PM
JCKnauer22's Avatar
Question 35's on stock suspension
ok, i know i have read several posts about low cog builds in the past, but i have searched and searched and i can't find what i'm looking for. i know i could just PM planman but i want this to be available for others in the future and i'd also like to hear what everybody has to say. currently, i am running a 1" bl with chopped fenders and a stubby front bumper. i know i will need to trim the pinch seams and rubi rails, but what else would be needed to run 35's? i plan on 35x12.50x15 pitbull rockers on 15x8 crager v-5's with 3.75" backspacing. i already have 4.10's and a manual, so gearing won't be an issue. if anybody has any photos of a similar setup please post em up. thanks in advance for any help
Old Oct 25, 2010 | 10:48 AM
Jeep(NV)'s Avatar
I am very curious about this setup.. Anyone??
Old Oct 25, 2010 | 10:52 AM
Pluke the 2's Avatar
https://www.jk-forum.com/forums/show...7s+lift+report
Old Oct 25, 2010 | 12:13 PM
Olean NY Jeeper's Avatar
In addition to the body lift, U will need flat fenders for sure and extended bump stops from what I have heard.
Old Oct 25, 2010 | 03:38 PM
Jeep(NV)'s Avatar
Originally Posted by planman
With flat flares and a 1" BL, you can run 35s with stock front bumpstops and adjust your steering stops to not rub the tires against the frame on a full lock turn.
However, in the rear you should consider 1"-1.5" extended bumpstops, or you may need to trim more than just the front lower edge of the rear fender well pinch seam.
With 3.75" backspaced wheels you won't need as much rear extended bumpstopping as with 4.5" backspaced wheels.
Go ahead and put the 35s on, and then make adjustments as you go.
A 1" rear extended bumpstop is not a really big deal, but if it takes more, I would either cut or do a BB with the taller rear bumpstop.
Sent from my DROIDX using Tapatalk
What if you have a Teraflex leveling kit any issues their?
Old Oct 25, 2010 | 04:13 PM
FrankTheTank's Avatar
Default Low COG build in progress
https://www.jk-forum.com/forums/show...acers-with-35s...
Old Oct 26, 2010 | 07:56 PM
JCKnauer22's Avatar
thanks for all of the feedback. i love this forum! i think my setup with the 3.75" backspacing is what i'll go with and start trimming as needed. if needed i can snag a set of pucks to give that extra bit of clearance. i want to avoid an actual lift since eventually i'll be running 37's but right now i don't have the money for any of the 3"-3.5" lifts i want. i don't want to pay money for something i'll be removing later, but if i go with pucks i can always use them later to correct for sag or excessive weight.
now all i have to do is save up for the 35's and wait for these damn rubi tires to wear out
Old Oct 27, 2010 | 03:58 AM
Why wait for the rubi tires to wear out? There is an incredible market for used tires. Use the money u get from the tires to put towards new ones. If u wear them down too far, they are worth nothing. I always sell tires well before they are useless for this reaso, plus heavly used tires suck off road.
Old Oct 27, 2010 | 07:56 PM
MoabBrink801's Avatar
Is there a write up on how much and where to trim I have a 4" lift and 37" mtrs I trimmed the rock rails and the bottom corner of the punch weld ... And going to flat fenders But it looks like I need to do alot more trimming and or a body lift. Any other places to trim
Old Oct 28, 2010 | 01:47 AM
JCKnauer22's Avatar
the biggest reason is that my stockers are pretty heavily scarred from wheeling. one has a very slow leak and the rest have so many scratches, gouges, and small chunks missing that i wouldn't feel right selling them to somebody.
