37" tire pressure .........?
Old Dec 17, 2010 | 08:52 PM
fitzb's Avatar
Default 37" tire pressure .........?
Whats the best tire pressure for 37"'s ??????
Old Dec 17, 2010 | 08:55 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
from the sticky in here:
On the road, what PSI should I be running in my tires?
A: For optimal comfort and even tire wear. you should not run the recommended PSI listed on the sidewalls of your tires. Typically this will be way too much. On average for a 33" tire, I would recommend that you run your tires at approximately 28-30 PSI. For a 35" tire, I would recommend running approximately 26-28 PSI. For a 37" tire, I would recommend approximately 24-26 PSI.
do the chalk test method for exact psi.
Old Dec 17, 2010 | 09:07 PM
JKCANADA's Avatar
I've been running 30psi in my KM2's, I personally like it... I ran a little more (32) in my 35's and they wore great, very even. So far I'm happy with 30psi, but that's just me.
Old Dec 17, 2010 | 09:19 PM
Red Dog's Avatar
I run 28-30 PSI in my 35’s. So I would think that with 37’s you might want to try 28 PSI and work down. You know you got too far when you don’t like the feel when you are driving or you gas mileage goes to hell.
Old Dec 17, 2010 | 09:25 PM
CALIJK's Avatar
Just my preference for 37s: 30 to 32 psi on the highway. 12 to 15 psi on the trail.
Old Dec 17, 2010 | 10:25 PM
RRauzer's Avatar
Granted I havent' tested them out too much yet, but I'm running 29psi on road and like the handling so far... KM2s
Old Dec 17, 2010 | 11:35 PM
nthinuf's Avatar
Start with what was suggested in the FAQ's, and then start experimenting with chalk tests and test drives.
My 35's feel 'squishy' at the psi most on here recommend, so i run them 4-5psi higher. Add another 5, and the ride gets rougher and more flighty. It's all about contact pattern and where they feel right to 'you'...
Old Dec 18, 2010 | 05:58 AM
kntr's Avatar
What is the lowest you can run without the light coming on?
Old Dec 18, 2010 | 07:29 AM
JPop's Avatar
This is going to widely vary from one tire to the next. The amount of air I ran in my 125 Service Description Toyos is far different than what I would run in my 111 Service Description Goodyear MTRs.
A good starting point is subtracting the new tire service description from the OEM service description (for practical purposes 112). Then reduce your tire pressure by the result according to the placard data. It's not perfect, but a decent starting point for on road use.
Old Dec 18, 2010 | 07:35 AM
wiredawg_mg's Avatar
I run 26 on the road and 9 offroad with D rated Iroks.
