37's on 17's?
Old Jan 24, 2011 | 07:28 AM
JacKed 8's Avatar
Default 37's on 17's?
Hey folks -- I'm wanting to pick up a set of AEV Argent Pintlers, and run 37's....is there a maximum tire width to run safely on the 17 x 8.5? Or am I gonna have to do something else?
Old Jan 24, 2011 | 08:12 AM
MOPWR2U's Avatar
The issue will be backspacing with those AEV wheels. AEV uses more backspacing, around 5.25" instead of the usual 4.5" that is recommended with aftermarket wheels. You may want to confirm with AEV if they will work, but if there is a problem it won't be because of an 8.5" wide wheel. I'm running 37x12.50s with a 17x8 wheel, but I have 4.5" of backspacing.
Old Jan 24, 2011 | 08:14 AM
JacKed 8's Avatar
The pintlers state that they are 4.7" of backspacing....so putting a 12.50 on a 8.5 isn't going to be a major issue?
Old Jan 24, 2011 | 08:22 AM
blockrockin's Avatar
yeah aev's are 4.7 you shouldnt have a problem..
Old Jan 24, 2011 | 08:26 AM
JacKed 8's Avatar
Thanks guys thanks for the input now I just gotta pick a 37" tire
Old Jan 24, 2011 | 09:37 AM
07rubisteve's Avatar
37's x13.5 here on the pintlers.....I run a 1.5 inch spacer...as I had a bit of rubbing at full lock in the frame..all good now..love these tires and the wider look
aired down to 8 psi here.
Old Jan 24, 2011 | 10:17 AM
jeep2007's Avatar
07rubisteve....sick Jeep!
Old Jan 24, 2011 | 12:22 PM
JacKed 8's Avatar
good lookin' Jeep TF states that you can run a 37" tire with their 4" lift, so do you have to run the spacer? Also, any ideas on where to get the best price on a 37 x 12.50/13.50 x 17 tire?
Old Jan 24, 2011 | 03:39 PM
duglas's Avatar
I have 37X 12.5" and run 1.5" spacers also..
still rubs in back a little @ 15PSI and full flex..
Old Jan 24, 2011 | 04:25 PM
Jeeps look great in two ways: really clean or really dirty, and that's a pretty dirty jeep
