4.10 Gears??
My '08 2 dr X 6-speed has the 3.21 gears, a D30 up front and a D44 in the back. I'm running 33" BFG M/T's and don't plan on going bigger. My lift is the RE 2.0 coil spacer with RE monotube shocks and JKS discos. I run mainly 2.0~3.5 rated trails.
I have two questions....
- what do you think about running 4.10 gears with my set up?
- do you think I need to add anything to beef up my axles or lift if I install the 4.10 gears?
Thanks for your inputs....
I wouldn't think your lift has much connection to what gears you install. As to axles, I don't know. I have 4.88 in an auto with D30 front and D44 rear with stock axles without any problems so far.
formulas
do a quick google search for gear tire RPMs
I'm running 33s and 4.10s and six speed. Most of the time it's just fine. However, throw heavy vehicle weight, highway and high winds together, and I sometimes wish I had a bit lower gearing. If I was paying someone to install gears and the 4.10s were free and another set cost me typical money, I'd spend the extra coin. As for mod's to beef up: I run some pretty tough trails on occasion and have not had a problem (yet!). I do plan to eventually gusset the Cs on the D30.
Then again... my still not entirely convinced I have 4.10 gears even after verifying with my dealer. After testing and using the above charts as a reference, my numbers are not even close to matching what's on the chart. In fifth gear at 70mph, my tach shows 3100 rpm which would lead me to believe than I'm closer to a 5.13 gearing...
GPS verify your speed and post the results.
Okay... after more research and reading the post here, I believe 4.88 gears would work better with 33's and a 6-speed. It seems to be a good compromise between mileage and performance. Agree or disagree?
